Saving A '97 F150 4x4 4.6L (Windsor)
Old 11-11-2014, 08:49 PM
DallasFan76's Avatar
DallasFan76
DallasFan76 is offline
Smile Saving A '97 F150 4x4 4.6L (Windsor)
Please, can someone tell me if the motor out of a '99 F150 4x2 will fit into my '97 F150 4x4 4.6L (Windsor). I blew the head gasket, (I hope thats all) and I found a wrecked truck with a good motor. Any help would be appreciated.
Old 11-16-2014, 10:22 AM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Old 01-01-2022, 06:30 AM
Wayne Clark's Avatar
Wayne Clark
Wayne Clark is offline
Eng swap
I think the 4.6 eng are the same but the 97 has coil packs & the 99 has a coil on plug set up. I also have read the cop set up can be modified to operate on the coil pack ecm in your 97. Unless that's your cup of tea I would just use the coil packs.
you might need to change to the 97 Intake as the fuel system is a return set up I'm not sure about the 99 if it is a return style your good.
Old 06-18-2022, 08:47 PM
Airborne 82nd's Avatar
Airborne 82nd
Airborne 82nd is offline
Like others have said swap the plug wire with another to see if the misfire moves I think you may not be seating the wire on the plug. Are they factory ford wires?
ekers88
Engine Swaps
06-24-2004 09:25 PM
gimiller
Modular V8 (4.6L, 5.4L)
05-26-2001 10:51 PM
Quick Reply: Saving A '97 F150 4x4 4.6L (Windsor)
