I can supervise someone putting up-pipes in their vehicle, tell them how to remove the RH inner guard, reach the manifold bolt with a 10mm socket on 2 extension arms, and use of a ratchet spanner. How to lye across the engine and wrestle the baby's butt onto the back of the turbo whilst getting the pin to align with the hole in the turbo outlet and at the same time tightening the bolt on the clampy thingy which you're also holding tight.
Yes, hours of fun and laughter to be had with up-pipes!
I would like someone to supervise me greasing up the front hub bearings though, so I'm sure I can provide plenty of laughs there while someone explains to me what I should be doing as things turn to custard doing that!
__________________
Mods done: lots and lots of cheap mods
Mods NOT done: big oil, big exhaust (other than the tip), big brakes, DP tuner
Next mods: HPOP (big oil), big exhaust, 38R, DP tuner, stage 2 injectors
__________________
Brian
03 F250 XLT LB Slowly working towards 500HP - In The Truck - 38R, F6, RR, aFe II, 4" turbo back, Gauges and some other stuff. -On the Bench250/100's, Terminator HPOP, Sage 1 cam, OEM pushrods, Fluidampr, ARP Head Studs, Comp 910's and counting
- cant wait until my motor blows so I can blame someone else - join the Australian Chapter here-Join Chapter
Brian, if you're ordering the o-ring kit - order 2 and I'll go you halves in the freight/postage.
__________________
Bryan, air leaks in your suspension, air leaks in your hubs, the HVAC works on the same air pressure as well you know.
While you're getting rid of your air-pressure hubs you may as well go the whole hog and put steel springs in your suspension!
__________________
Exactly wot im doing,putting my pro comp supension back on,maybe heaps rougher but its reliable.
__________________
Bryan.
2005 FORD F250 7.3L, BFG KM2's 305/70 R16's 33",16x10 alloy rims,5"Procomp/Icon Vehicle Dynamics lift,AIH Delete,CCV,FRX,HPX, OCR,JW valve body,mag-hytec rear diff cover,wicked wheel,Garrett turbo outlet,F6 chip,Custom 4" to 5" exhaust,All from clay @ RiffRaff,BD big trans sump,Carpc(3.02ghz CPU,2G ram,Asus MB 1333,160G HDD,Asus GTX 210)10" touch screen
Bryan, presumably you just have to insert coil springs in place of the air bags. At least you'll be off leaves!
You might be able to salvage a fair bit of your air-control gear if you can get those helper-bags which fit inside the coils. You'd virtually run the same system, but the bags would just be for firming the ride up on the tarmac or getting a little bit more clearance off the tarmac.
A foot in each camp so to speak but not exactly AC/DC
__________________
1. Bryan & Lyn (Nkelly)
2. Simon (SSSimon)
3. Geoff (Ratkat)
4. Rod (Loaf4000)
and another 3 trucks (non FTE members)
__________________
Brian
just a reminder, if you want your parts here by the time Clay is here you better get it ordered.
__________________
Brian
Hey Clay, if I order one of the John Woods 4r100 valve body will you be able to bring it over for the wrench session? Obviously you'd be able to take my stock one back as the core.
Does the fact that the Aussie trucks have the PTO transmission complicate the valve body swap?
__________________
Valve Body will be the same, but I can't really take that kind of stuff through customs.
OK will order the JW valve body tonight ozzie time!
Now any recommendation on what's the best ATF to go and buy a 20lL drum of?
Also, funny thing happened to me in my truck in SYDNEY on the w/e. The HVAC got stuck on demist! Anyway, as we all know it is air-pressure actuated. I popped the hood and wiggled the air line off the pump. The pump started and a pushed the airline back on. Then checked the HVAC and it was working fine again. Somehow it got temporarily stuck on demist and pulling the air line freed it up.
HAVE NOW ORDERED THE JW R4100 SHIFT BODY FROM RR. I also ordered the overboost regulator kit. Funnily enough on the way to Sydney towing the boat up a hill the CEL came on - I'd say it was an over boost situation. Soon after on a flat bit of road the CEL went out.
Couldn't order the front hub seal kit from the Diesel O Ring site due to having a non US/Canada shipping address
Also note to Brian - can we also arrange someone to be in charge of taking photos of the wrench sessions. It would be good to get a few tech write ups with photos of the actual event with special guest Clay, and of a few a the session that we do.
__________________
Reason: Added order details
