an 03 compressor wheell doesnt have as many fins, and doesnt move as much air. an 05 should be able to get over 20psi easily. i coud get mine to push 25+ stock.u have some problem swith ur vgt or actuator, but im not sure what.
My stock 2003 will hit 27-28 as measured on my Isspro boost gauge.
26 to 28 should be the safe max on any stock 6.0. Flat level ground on the highway at 70 I will run about 5 psi. Punch it and I get about 22. Put the fifth wheel on it and I approach the 26 to 28 mark. The gauges are kind of iffy in this range. Refering to the marks and lack of numbers in this area of the gauge.
bone stock with my 04 6.0 I can run 24 to 26psi. with my quadzilla turned up to 65hp the towing level I can hit 27 to 29psi. Nothing ever over 29 I have seen.
