New Guy ford stuff on Oshkosh Chassis need help
Hi Everyone,
Not sure if this is the right forum, but here goes
Got a 1991 RV with an Oshkosh chassis and a ford drive train.
Had an issue with the motor, started the motor, it made a horrible sound and before I could shut it off it went Clunk and stopped. Turns out the starter solonoid failed and held the starter engaged with the flywheel and the starter imploded and siezed stopping the motor
Got a new starter and solonoid installed, turned the key, it's a ford key, and nothing lit up, found the ignition fuse blown, changed that and still nothing. I suspect the ignition switch got fried.
I have pulled the steering wheel, removed the cruise stuff and directional stuff etc I see the tumbler with the key now where the heck is the starter switch?
just below the key is a column cover with two screws, removed the screws but can only pry the cover apart a little to peer in there, I am afraid to break the cover. I see two blue wires but they look like they go to what I think is a neutral starter switch
Help, I need pictures
on
Not sure about oshkosh, but the ford trucks have fusible links that come off of the starter relay near the battery. They look like a normal wire but burn in 2 when too much current is run through them. Sometimes they dont burn the insulation off, but if you pull on them and they stretch the wire inside is burnt
Does it have a name other then ford truck ignition switch?
on
Wow who woulda thought I just looked and there it was in the worst possible place. Can I loosen the column some to get at it or do I have to go by feel. Any pictures showing me what I am looking at will be a big help.
Pretty much it's exposed on a Ford truck. If they flipped the column upside down, you may have to drop the column (four bolts) to get to it. Mine was attached to the column by two Torx-headed bolts.
Are you planning on just replacing it and seeing if that fixes it? Got a test light? I suspect a problem at the starter solenoid, thats where the fusible links are that supply power to the ignition switch. Maybe you didnt get all the wires hooked back up when you replaced it.
This is possible too - I'd check on this first.
If I recall correctly, it's called the "ignition actuator" or some such at times.
Any way should there be any wires other then the heavy wire to the starter be attached to the switched side of the solonoid?
Our RV has a pair of 12V house batteries and there is an emergency start setup in which I can use the house batteries to start the motor if the motor battery dies. The small wire connected to the switched side of the solonoid might have something to do with activating a relay while the key is trying to start the motor to send house current to the starter solonoid.
Any way I got the switch out and am gonna run to the store and get a new one, mine is loose on itself the electrical side if very loose from the mounting side I can almost pull it apart.
I hate to throw parts to see if I can fix something but this switch is only 12 bucks
Yea the old switch was almost falling apart. clipped in the new switch and nothing, must it be bolted in place? I just clipped it into the wire bundle and slid that slide back and forth to see if anything turned on, nothing did
I cannot find anything like a fuseable link, is there a main fuse possibly hidden somewhere
on
