FAQ - Towing Capacities
https://www.ford-trucks.com/forums/7...ml#post6259359
According to the 1981 F-150 Owners Manual.
Trailer Class I
tounge load 10 to 15% of trailer weight, 200LBS max.
Trailer weight, up to 2000LBS.
Cooling package, Extra Cooling.
towing package: LD
Trailer Hitch: Weight Carrying
GVWR MIN: 5020 / 5800 / 5450 / 6100
GCWR MAX: 7050 / 7600 / 7250 / 7900
Engine Required:
4.9L / 5.0L / 5.8L
min axle ratio 3.00
Automatic transmission required.
Trailer Class II:
tounge load 10 to 15% of trailer weight.
Trailer weight, 2000 to 3500LBS.
Cooling package, Super Cooling.
towing package: HD
Trailer Hitch: Weight Distributing
Stabilizer bars: Front and rear
GVWR MIN: 5250 / 5800 / 5450 / 6100
GCWR MAX: 8225 / 8775 / 8425 / 9075
Engine required 4.9L / 5.0L / 5.8L
min axle ratio:
4.9L and 5.0L: 3.25
5.8L: 3.00 (3.25 Canada)
Trailer Class III:
Trailer weight, 3500 to 5000LBS.
towing package: HD
GCWR MAX: 9500 / 9800 / 9700 / 9800
Engine Required:
5.8L
min axle ratio 3.00, 3.25 in canada.
You have to upgrade to a F-250 to tow more, according to the manual.
So according to the 1981 owners manual, it doesn't recomend you tow anything with this vehicle at all. (possibly due to clutch wear and warrantee) though in my personal experience, 2000LBS would be maximum without mods, IMO.
Trailer Class I
towing package: LD
Engine Required:
4.9L / 5.0L / 5.8L
min axle ratio 3.00
Trailer Class II:
towing package: HD
min axle ratio:
4.9L and 5.0L: 3.25
Trailer Class III:
towing package: HD
Engine Required:
5.8L
