Demething Bio
Old 02-06-2012, 05:55 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
I'm using a 4'X8' heat exchanger from an old steam boiler in an insulated box with a thermopane window, on the roof of my shop, and a smaller heat exchanger in the 500 gallon tank. I plan on using a 50/50 mix of glycerol and water for the transfer liquid.
I also plan on installing a valve set so I can transfer the heated fluid to heat the shop when I'm not using the tank.
I tried a small test last summer with a hundred foot coil of black plastic pipe on the roof of my shop, and developed 185 deg temps with a 4 gal/min flow.
  #32
Old 02-06-2012, 09:30 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
185 degrees is pretty impressive. My partner was thinking about doing something like that himself...
  #33
Old 02-07-2012, 12:47 AM
97biostroke's Avatar
97biostroke
97biostroke is offline
That'd be something fun to build. I've got enough on my plate with switching to dry washing as it is though.
  #34
Old 02-09-2012, 04:27 PM
97biostroke
Forgot one simple question. How long does it take you to demeth your fuel? Im just looking for a roundabout number, trying to decide how to build the new setup.
  #35
Old 02-09-2012, 04:29 PM
fabmandelux
Depends on how big your tank is.......
My old tank was about 40 gallons and took a couple of hours to finish.
  #36
Old 02-09-2012, 04:33 PM
Rushmore X's Avatar
Rushmore X
I am thinking about 3 hrs or so. I need to make myself a more efficient condenser. It take awhile to heat up to 185 degrees, then I let it run until it slows to a drip from a steady stream.
  #37
Old 02-09-2012, 05:37 PM
97biostroke
That's about what I was expecting. What's the least amount of time needed to wait after the reaction to drain off the glycerine? It'd be pretty handy if I could do all that in one day, especially since the fuel would still be somewhat warm.
  #38
Old 02-09-2012, 05:42 PM
fabmandelux
I always wait a minium of 12 hours before draining the glycerol. I've tried lower times, but always had more fall out later, so I wait the 12 hours now.
  #39
Old 02-09-2012, 06:09 PM
97biostroke
I've usually waited overnight, but browsing through some forums I saw people waiting just 4 hours to drain. I'll stick with the overnight and design the setup around that.
  #40
Old 02-09-2012, 09:02 PM
Rushmore X's Avatar
Rushmore X
Do the same thing with the Magnesol. Let it settle overnight at a minimum and the filters won't have to be cleaned near as often...
  #41
Old 02-10-2012, 11:16 AM
TxFordGuy's Avatar
TxFordGuy
TxFordGuy is offline
I know it would be more expensive but can you use magnesol to rid all the methanol out of the batch? I thought i read somewhere you can spread the used magnesol outside. If you sun dry it good you can reuse it. false claim?
If you did not demeth first, how much magnesol would use use pricewise
and
How much magnesol do you use pricewise if you demeth first
  #42
Old 02-10-2012, 11:26 AM
fabmandelux
Without removing the methanol, about ten cents/gallon. Remove the methanol first, about 5 cents/gallon. The main reason I use it is because it removes any soap suspended in the bio and any water or methanol.
Magnesol should not be reused even if dried.......
  #43
Old 02-10-2012, 03:06 PM
97biostroke
What are your thoughts on using woodchips for dry washing?
sirnobody
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
04-23-2011 01:38 PM
Rushmore X
21
03-09-2009 09:10 AM
97biostroke
02-15-2009 01:55 PM
blkbeast
09-23-2008 03:25 PM
RUFUS2.9
Garage & Workshop
07-20-2005 10:40 PM
Quick Reply: Demething Bio
