Most Aggressive sounding muffler for 5.4?
I have a 3" flowmaster 44 with no cat on my truck right now that exits right before the rear tire and i really dont like it it sounds like all my friends jeeps its very low and droney it just kind of sounds like a big exhaust leak. So i am thinking of buying a 4" tailpipe off and a 5" tip off of summit i want to get a new muffler to but i dont know what muffler I should get any suggestions?
Definition of AGGRESSIVE
a : tending toward or exhibiting aggression <aggressive behavior> b : marked by combative readiness <an aggressive fighter>
a : marked by obtrusive energy b : marked by driving forceful energy or initiative : enterprising <an aggressive salesman>
: strong or emphatic in effect or intent <aggressive colors> <aggressive flavors>
: growing, developing, or spreading rapidly <aggressive bone tumors>
: more severe, intensive, or comprehensive than usual especially in dosage or extent
Here you go.
a : tending toward or exhibiting aggression <aggressive behavior> b : marked by combative readiness <AN aggressive fighter>
a : marked by obtrusive energy b : marked by driving forceful energy or initiative : enterprising <AN aggressive salesman>
The Mufflers
MAKE MODEL Part No.
SUMMIT Turbo 630125
THRUSH Magnum Glasspack 24214
THRUSH Boss Turbo 17718
HOOKER Competition 21006
DYNOMAX Super Turbo 17733
DYNOMAX Race Magnum 24215
HOOKER Super Competition 21106
SUMMIT Fully Welded 630325
FLOWTECH Afterburner 50322
MUFFLER FLOW TEST
MUFFLER Flow at 28-in H20
DynoMax Race Magnum 528.64 cfm
Thrush Magnum Glasspack 507.40 cfm
Summit Fully Welded 343.38 cfm
Flowtech Afterburner 342.20 cfm
DynoMax Super Turbo 333.94 cfm
Hooker Competition 232.46 cfm
Hooker Super Competition 320.96 cfm
Summit Turbo 331.16 cfm
Thrush Boss Turbo 297.36 cfm
MUFFLER Idle dB WOT dB
DynoMax Super Turbo 89 123
DynoMax Race Magnum 94 133
Flowtech Afterburner 92 124
Hooker Competion 92 122
Hooker Super Competion 90 125
Summit Turbo 89 124
Summit Fully Welded 92 125
Thrush Boss Turbo 90 123
Thrush Magnum Glasspack 92 128
DYNO TEST
All mufflers were dyno-tested on a 355-cube SBC with 10.0:1 compression, Air Flow Research 190 aluminum heads, a CompCams 292 hyd. a Victor Jr. intake, a Holley 750-cfm double-pumper, and 1 5/8 Headman headers.
While there are mufflers that will out flow a glass pack design, it also depends on the design. Does the glasspack use "louvers or perforations" - Louvers reduce the flow by as much as 50% but Allied resonators (that sell for $30-$40 each and available at any muffler shop) in independent test flowed 90%+ of a "race spec muffler". Others using other brands consistently showed similar results.
The CATS absorb about 60-70% of the sound........IMHO, I would go to a local muffler shop & have them drop the muffler...listen to it, it may be to your liking....if it needs the tone changed, then have them hold up different mufflers until you find "your sound".
I am running 2- 3" diameter, 24" long Allied resonators on mine.....they are very deep toned, nice rumble on accel/decel and little to no drone (depends if the weather is raining, then there is some, but very small- not enough to be an irritant). I (and my family) have used these on just about everything since the 60's and have never had one "fail" or loose it's sound, etc.
Personally, I like this setup best for the 5.4L engine. If you want it louder, just reduce the length of the mufflers. What I really like is the sound especially at high RPM's... there is no rasp in the exhaust note.
2004 F150 5.4L Magnaflow True Duals ( After Install ) - YouTube
I used to have a slp lm1 resonater after the stock cat and then i made a exhaust from the y pipe back with a 3" pipe no cat and a poopmaster 40 exiting before the back tire and it sounds like s**t. I am going to order a 4" dynomax tailpipe tonight and a 4 1/2" tip then for the muffler i am going to put the slp lm1 back on and get a high flow cat. I think it should sounds pretty good like that it did sound good with the slp before so with a high flow cat and a 4" tailpipe it should sounds nice.
Look to a Race Bullet. Only a couple of Db's below open header. Loud.
A lot of racers (hence the name) run these.
Also look to your local noise ordinance as well.
Dynomax® Performance Exhaust | Mufflers | Race Bullet Mufflers
Good luck!
Good luck!
__________________
Follow us on Facebook!
https://www.facebook.com/dynomaxexhaust
http://www.dynomax.com
