Modified B Rear Springs OR Roadmaster Active Suspension
The only way I'd go with both is if you are in my boat or if you KNOW you will be towing heavy and don't want to go with a WD hitch.
I'm almost wondering instead of RAS for my own rig, using an air bag system...that way I can run the air bags almost empty for daily driving, then use them to add lift to the Modded B's as needed and be able to dial it in level.
I think without my load the rear would ride stiff, but still not as stiff as a stock 250. I don't know this for sure, but my gut tells me the two added leaves to the B's are not taking the full weight difference of the rear body of the Excursion as compared to a bed of a F250.
I think the B's themselves take most of that weight and the lower leaves aren't really lifting too much until my tools and/or the tongue weight are factored in.
IF that's true (and I have no idea how I could prove it), then I think it would ride stiffer than a stock Excursion, but softer than a F250/350 without any special heavy-duty suspension.
I think if you ran Modded B's AND RAS, it would feel as stiff as a F250.
Stewart...WhiteBuffalo...etc...what do you guys think?
The ride with V code and Mod B's is very good. I am also running a 4.5" ICON spring hanger in front with a 6" block in rear. The shocks will change how the ride feels. The V code in front is stiffer than stock but still very comfortable. Well worth the handling advantages. The modified B code in the rear feels just as soft as the factory springs did with my Bilstien shocks from Caryt. I had some minor axle wrap when towing a 10500lbs trailer - partially due to the 80hp SCT towing tune and 4:30 gears - lots of torque on take-off. This was solved with OUO traction bars. Extremely stable set-up. The ride quality is extremely good both unloaded and loaded to the max. Even in highway expansion joints it just glides along. I have found no need for RAS with the WD hitch. If towing heavy without WD that is another ball game and the hitch is only rated for 500lbs of tongue without WD. My trailer has a tongue weight between 1100-1300lbs depending upon how it is loaded (measured at both the truck scales and with a sherline scale). With the mod B springs and my WD hitch I have between 1.25"-1.5" of sag in the rear. The front goes up around .25". Here are pics of the stance unloaded and loaded for comparison. Slight rake front to back unloaded.
Sits almost perfectly level with the trailer - about a 1/2" down in the back.
Again, about 25000 miles ago (November 2010), I installed new "V" code springs on front, new "B" codes on the rear with stock 2" block on rear, and then I added RAS to the "B" code springs on rear.
I measured the arch heights when I got it back to the garage--39" to bottom of arch on front, 41" to bottom of arch on rear. A 2" rake when unloaded.
Forest did you tow with just the B codes? Wondering how it towed with just the B codes. I have the stock springs with the RAS in rear and V codes upfront and I am pretty happy with the ride. I need to get some pics but some times it appears to squat a bit and other times appears level. I would like just a bit more rise in the rear. Thanks, John
#28
#29
#30
