Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Why Does My 4WD Make Noise?
Guide to diagnose trouble and recommended solutions
F150 5.4L strange rattling noise, PLEASE HELP, I need a idea!!
#47
Ok after looking on this site and trying to figure out what was rattling/ fluttering on my truck I decided to dig into it. The first thing I did was replace the IWE solenoid and it still made the noise so I then replaced the IWE actuators. I needed the passenger side but I went ahead and put on the drivers side also. They are not that hard to change by the way. I got them from amazon for $70 a side. I drove the truck and still the same noise. I took off the skid plates and made sure there were no rocks and still had the noise. I then took off the check valve closest to the IWE solenoid and notice I could freely blow though it. I went to the parts store and got a new generic check valve and still same problem. I checked the other check valve and I could freely blow through it also so today I went to the ford dealer and got both check valves, installed them before I drove home and the truck is super quite! No noise at all!! I recently had the phasers done but they make a totally different noise and it is only after warm up at idle. My suggestion is start with the check valves and then go to the solenoid. I am sure this will fix the problem.
#49
Thats It!
Is this the noise? https://m.youtube.com/watch?feature=...&v=SU-4fE9302w
Mark
Sweetrocks
2004 - 2008 F150
01-28-2012 11:02 AM
spike552
10-15-2009 07:45 AM
