coil spring spacers
Old 01-24-2012, 12:36 PM
FordOwnerJoey's Avatar
FordOwnerJoey
FordOwnerJoey is offline
coil spring spacers
Wheres a good place to get coil spring spacers at?
This is the style Im looking into, but not 1.5" maybe like 2 or 3" and for the front springs. Amazon.com: ReadyLift 66-3015 1.5" Rear Coil Spring Spacer: Automotive
If I do this, what else am I going to have to change on the front end since its a TTB 87 f150 (300-six, 4x4, 4 speed)
the rear Im thinking about just doing the shackle flip kit, my friend can get me one from someone he knows who makes them where the new brackets actually bolt right into the stock holes.
Anyone have any problems with these spacers?
Old 01-24-2012, 12:42 PM
andym's Avatar
andym
andym is offline
Coil spring spacers are not really the right way to lift a truck. I would get a lift kit instead. Anything more than 2" will require drop brackets anyway, and anything up to 2" will require new shims to correct the camber.
Old 01-24-2012, 10:56 PM
Thumper19's Avatar
Thumper19
Thumper19 is offline
I was always told to never use no more than .5" spacers under coil springs
Old 01-24-2012, 11:01 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
Well I got my 2" spacers off eBay. Seem I be good quality. But I haven't installed them yet that's my plan for this weekend
And the rear I'm goin with a 3" block to give it a bit more rake.
Old 01-25-2012, 12:04 AM
deljac's Avatar
deljac
deljac is offline
i have 2.5 spacers and didnt have to change anything. when i got the alignment they didnt need new shims. and essentually whether you use spacers or buy a lift with spacers your doing the same thing.
Old 01-25-2012, 07:35 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I'd only use leveling springs like what Superlift offers or replacement F250 springs from Moog.
Old 01-25-2012, 07:38 AM
TexasGuy001
I don't see the point to the 3 inch blocks. Then it'll have even more rake than stock. If you are going to put rear blocks on, go with 1.5.Don't get aluminum blocks. Get name brand cast iron or steel.
Old 01-25-2012, 08:06 AM
Midnite1987
The blocks are procomp blocks so they are name brand. I was originally looking for the cast ones but my local off road shop had these in stock and gave me a good deal
When looking at my truck from the side it almost looks level as it is. So I wanted to bring the back end up a bit farther then the front I like the look with the back and a bit higher (not drastically raked)
Old 01-25-2012, 09:49 AM
andym's Avatar
andym
andym is offline
Unless either your front springs were sagging 2.5" from their stock height, you used i-beam drop brackets, you have a solid front axle, or your tires look like this: \--/ then what you say here is not possible in the universe we live in.
Old 01-25-2012, 10:40 AM
TexasGuy001
Like Andy said there us no way the alignment isn't off if the front has been lifted.
I don't care if the rear blocks are name brand. If they are aluminum I wouldn't use them on anything. The same goes for the front ones. What material are they?
Old 01-25-2012, 11:17 AM
Midnite1987
Front blocks are delrin
Old 01-25-2012, 11:30 AM
Midnite1987
I didn't like the the aluminum block idea either. I just found a set of 2.5" cast ones for 1/3 of the price of the aluminum ones so gunna bring them back and pick up the cast
Old 01-25-2012, 11:36 AM
andym's Avatar
andym
andym is offline
I don't know why anyone would even make aluminum blocks. To save weight? lol
Old 01-25-2012, 12:14 PM
Midnite1987
Not sure but they were $125 compared to the $45 for the cast ones. The aluminum just had offset pins not a taper...
Old 01-25-2012, 12:54 PM
deljac's Avatar
deljac
deljac is offline
when i put mine on it brought my front end up a little higher than level. think what ya want but my alignment is good and i didnt change anything else.
Quick Reply: coil spring spacers
