Search: Ford F1 1952 4-speed Transmission
Old 01-22-2012, 04:38 AM
rosthaufen's Avatar
rosthaufen
rosthaufen is offline
Hello togehter,
i search some tuneup parts as:
Syncr, drive gear, rears etc.
BR Greg
Old 01-22-2012, 07:04 AM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I have a whole trans that I dont need if your interested.
Old 01-22-2012, 08:16 AM
rosthaufen's Avatar
rosthaufen
Ford Transmission
That's fine..I really needed only parts, but if you have a very good transmission..
Please send me some pictures and what will it cost
to old_mcgreg@web.de
many thanks
Greg
Old 01-22-2012, 10:09 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
It would be helpful if we knew exactly which model of transmission you have, and which gears you need. There should be numbers cast on the side of the transmission case. And if you can post pictures of your damaged parts, we may be able to match them.
Old 01-22-2012, 02:00 PM
brain75's Avatar
brain75
brain75 is offline
From the research I have done previously I am guessing only he's talking about one of two transmissions, the rock crusher (markings T8D-1A or 4TA/4Tb) or the synchro silent 4 speed (markings 4TH or T98).
No synchro on the rock crusher... and if you are willing to wait till I finish my T5 swap I have a whole rock crusher verified working (I'm driving on it right now) I'd let go for a song and a dance :p
Old 01-22-2012, 02:40 PM
mtflat's Avatar
mtflat
mtflat is offline
Like the guys have indicated, it's not very likely your F1 has a synchro trans.
When you find out which you have, contact Joblot Automotive in NY for the specific parts you need. I'm sure they've shipped to Germany before.
Old 01-29-2012, 12:04 PM
brain75's Avatar
brain75
brain75 is offline
Are you building a museum piece or a practical drivable vehicle?
I saw you visitor message, and just have to double check before discussing the T8 seriously. No synchros, no overdrive, and low is geared for lower than towing - clear down at rock crawling. The stock T8 is undesired, nobody keeps them they all end up in salvage. They weigh 175 pounds (85 kilos), shipping to Germany would be a mint. If you are going to all the effort to put this back together as a usable vehicle I would look for a T-5 and the pieces and parts to convert it over. The T-5 weighs 75 pounds (34 kilos) and is sold internationally (the S-10 donor truck is sold in Brazil and USA but not Euro that I know of).
Old 02-21-2012, 04:08 AM
rosthaufen's Avatar
rosthaufen
Ford F1 1952 Transmission (no Steering wheel shift)
Thank you for your help. What transmission would you recommend me
Old 02-21-2012, 02:51 PM
brain75's Avatar
brain75
brain75 is offline
My focus has been on US available transmissions. I did some digging to see if the Chevy S10 pickup version T5 is available outside the US, but so far it doesn't look promising.
Time for some of the European friends to step up and chime in - what did you guys find for options?
Old 02-21-2012, 08:27 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
If its an f1 then it has the T59 or spur type. A T98 will not bolt into an f1 chassis.
Old 02-22-2012, 04:49 AM
rosthaufen's Avatar
rosthaufen
Transmission
Hello together,
yes, it is a 1951 F1 with stock 4-speed (not synchro) transmission!
The T98 is a 4-speed synchro transmission, is that right.
OK i need this..
Who can help???
The shipping goes on CA not Germany!!
Old 02-22-2012, 02:29 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
As fifty-two_f1 said, a T98 is NOT going to fit in your F1 without swapping the transmission crossmember, master cylinder, and pedal assembly to one out of an F2 - F6 truck. The crossmembers are riveted in place and changing them is no small task - and that's after you've found a T98 to put in. They aren't so easy to find. In my opinion, there are better choices. I'd either go with a T5 swap or a stock light duty 3-speed.
Old 02-22-2012, 04:31 PM
fifty-two_f1
Only the real men put t98s in their trucks..... those weirder individuals go with zf5s and Fuel injection.... bleck!!!!
Old 02-22-2012, 06:33 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
T98s from later trucks are fairly easy to find. Starting with the 1953 trucks all the four speeds were T98s. This stayed true through the 60s. I am not sure what differences in the T98s there are between years.
Old 02-22-2012, 07:55 PM
fifty-two_f1
The 48-52 T98s have the bellhousing that will bolt up to the flathead 6s and 8s and the 215 ohv. The 53-56 T98s have a different mount in the front and have no rear mount, they hang from the bellhousing..
Quick Reply: Search: Ford F1 1952 4-speed Transmission
