Loner's build 1984 f150 460 BBF
Old 05-13-2014, 08:05 AM
loner-dwp's Avatar
loner-dwp
loner-dwp is offline
Originally Posted by Chris Guthro
looks awesome man! glad you decided to keep it. so what pistons are you using with the d0ve heads? im at that stage now and dont want a sky high compression ratio. did you also decide on a cam??
Thanks man!
Well I am actually not going to use the D0VE heads, I was doing more resarch over at 460ford.com and it seems for the power goals that I have, it would cost me more money to use the early heads vs the late heads.
As for a cam I was looking at this cam.
http://www.summitracing.com/parts/lun-80460lk
But If I were to use the D0VE heads, I would try to reuse the stock pistons to keep compression around 9.5.1 depending on deck height.
Originally Posted by 5280
Great looking truck. Glad you decided to keep it.
Following your engine build with interest as I'm fixing to do the same to mine in the future. I picked up a pair of C9VE heads to attempt to port
Good stuff man, have you checked out Scott's website for porting instructions, that website is amazing!
Re in"Car"nation High Performance - Home
  #122
Old 06-15-2014, 06:30 PM
86f150lariat's Avatar
86f150lariat
86f150lariat is offline
What suspension are you going with? I have an 86 with a 302 and I'm about to swap it out with a 460
  #123
Old 06-17-2014, 08:30 AM
JordanL91's Avatar
JordanL91
JordanL91 is offline
Originally Posted by loner-dwp
Thanks man!
Loaner, I am about to do a similar build, Do you know if the C6 fit with the old AOD mounts? did you have to Fab anything. I read this whole post, Good job! I did have a few questions...
Do you by chance know the brand of your mirrors?
Also did you buy stock replacement springs or was it DJM brand?
You said the rear shackles were a 2in. drop, is this correct?
Did you ever end up adding more performance to the engine?
What was the point of the F250 sway bar as opposed to upgrading the F150 Sway?
  #124
Old 06-19-2014, 09:01 PM
86f150lariat
Doing same swap
What about our driveshaft? My dad said I may need to get someone to shorten it. I've never heard of it.
  #125
Old 06-19-2014, 09:07 PM
JordanL91's Avatar
JordanL91
That is affirmative the driveshaft, is actually the easiest part of the swap go to a driveshaft specialist it'll cost you like 200 dollars.
  #126
Old 06-29-2014, 06:54 PM
loner-dwp's Avatar
loner-dwp
Hey guy's, well life has decided to change my plans. And I won't be rebuilding the engine this year like I had planned. So it looks like it will be on the backburner a little longer. I don't have the time to rebuild it before I move now.
ideally, I would like to get a crown vic front end, but one can dream.
1. The mirror's were stock, off my dad's truck. But I think **** or other brands make the same style for like 30 bucks.
2. I ended up using stock replacment springs Moog #820, I had tried the "heavy duty" spring, but it caused the front to sit way to high for me.
3. Yes the rear has a 2in shackle drop by DJM.
4. The 460, has the basic bolt ons, headers,intake,carb, and msd box. Nothing fancy.
5. Ahhh yes the f250 sway bar, I never did get around to changing that. But My thought process on that was, it was a mucher thicker swaybar than the f150.
I had to get a driveshaft made, when I did the swap.
The only thing I Could add to this, is make sure you take your measurments accuratly.
  #127
Old 06-30-2014, 08:22 AM
JordanL91's Avatar
JordanL91
From what I have found out on this forum, you actually are better off replacing all the front end bushings, upgrade to polyurethane. Change out the steering box with a redhead steering box, and you should be pretty content
  #128
Old 06-30-2014, 12:53 PM
loner-dwp's Avatar
loner-dwp
From what I have found out on this forum, you actually are better off replacing all the front end bushings, upgrade .,to polyurethane. Change out the steering box with a redhead steering box, and you should be pretty content
Yea I'm sure if all the bushings were replaced, I would be happy with it. But staying with the i beam style front end. It really limits your options.
I want the truck low, like as low when I first got it. And using a crown vic front end, I think would be the best route. Its a better suspension deisgn, also there is tons of options to upgrade, from coilovers to bigger brakes. Plus it changes the lug pattern to 5x114.3, if I remember correctly, which has a ton more options for wheels, compared to the factory. 5x139.
But like I said, I am dreaming. And that would be an ideal set up.
  #129
Old 06-30-2014, 03:20 PM
JordanL91's Avatar
JordanL91
Never hurts to dream imo, I have already put to much into my motor build it all started with a dream unfortunately!
  #130
Old 06-30-2014, 11:20 PM
loner-dwp's Avatar
loner-dwp
What is your motor set up gonna be like?
  #131
Old 07-01-2014, 06:37 AM
JordanL91's Avatar
JordanL91
Its the 302 EFI rebuild thread... Its a .030 Overbore, Flat top pistons Heads intake, pretty much the works, I also invested into the Fast EFI throttle body because the stock EFI was crap and restrictive...
  #132
Old 07-01-2014, 07:14 AM
JordanL91's Avatar
JordanL91
Hey also do you mind explaining your suspension set up? I cant seem to find any products you related to?
  #133
Old 07-01-2014, 10:38 AM
loner-dwp's Avatar
loner-dwp
Yea for sure. The front has Moog replacement springs #820, the front springs also have Mr.Gasket coil spring compressor's. The shocks are Monroe, I believe I can't remember.
Then the rear has the DJM 2in drop shackle for the leaf springs, Also I believe it has Monroe shocks.
Wheels are 15x8 with a 0 offset. Front tires are 255/60/15 Bf Goodrich and the rears are 275/60/15.
http://www.summitracing.com/parts/dj...rd/model/f-150
http://www.summitracing.com/parts/mo...rd/model/f-150
http://www.summitracing.com/parts/mrg-1280
  #134
Old 07-01-2014, 11:32 AM
JordanL91's Avatar
JordanL91
Hahah my luck the coil sping kit is no longer available, You never addressed my question of the C6 bolting in just fine on the AOD tranny mounts?
  #135
Old 07-01-2014, 05:28 PM
loner-dwp's Avatar
loner-dwp
I am sure you can find the coil spring kit somewhere, maybe a local auto parts store has some on the wall. Thats where I got mine.
Sorry about missing the trans question. Honestly I have no idea about the C6 and AOD mounts. I haven't had any experience with that. But I did ask google, what she thinks about it.
1984 F150 2WD C6 to AOD swap - Ford Muscle Forums : Ford Muscle Cars Tech Forum
Quick Reply: Loner's build 1984 f150 460 BBF
