more power please
Welcome to FTE! We're glad you have found us. There is a ton of great info on here and people that are willing and able to help you with most any problem.
For your question you can try this first
Ford Truck Enthusiasts Forums - Search Results
This question has been asked many, many times.
We also have a forum dedicated to just this engine
Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) - Ford Truck Enthusiasts Forums
Start reading, and when you have a specific question we'll be here to help
Two things I did to my '96 F350/460 truck.
Remove the rubber intake tubes, there is a center plastic section. On the air filter side of that plastic piece there is a restriction tube. It is there to remove "noise", kinda that 4bbl no air cleaner lid type sound. Using a hacksaw, cut them off, but leave enough to secure the pipe back on.
If you run good enough gas, you can also bump the timing up a couple degrees to add some umph. Remove the spout plug, start truck and add timing. Shut off and install spout.
With those two items, mine went from "lame" to actually being able to turn the tires from a stop(not powerbraking, just matt the throttle). Not bad for a 1 ton dually. Mine drug my 14K trailer without too much hassle.
upshotbravo
04-19-2013 05:58 PM
Lmkonzen
02-21-2012 09:23 AM
Big-old-460
02-15-2010 03:35 PM
boaterdude83
09-17-2008 11:03 PM
