Could this really work?
Check this supercharger thing out ELECTRIC TURBO POWER AIR INTAKE SUPERCHARGER KIT FORD
I was just browsing around on eBay and I stumbled on that... It kind of reminds me of that passive cyclone thing they had on TV 5 or 10 years ago that was supposed to make the gas and air mix better because of the spinning action...
Seriously though, could a cheap electric fan like this provide enough boost that it would make any real performance gain? Would this screw up the engine by making it run too lean? or would the air sensor thingy in the intake account for that?
I am not seriously considering it, seems like too cheap to be good or real. But then again just replacing the factory air box with a decent cold air intake does make an improvement on every vehicle I've ever had...
Glad you are not considering it. These have been discussed on other forums for fuel economy and such. Disproven many times. If anything, it will restrict air flow unless that fan is pulling some serious amperage.
Electric turbo power air intake supercharger kit ford - 2003-04 Mach 1 Registry Owners Club
I think a snorkel would work better for about the same money.
Good to know, like I said I wasn't seriously considering this thing, but I had to ask. If this really worked then everyone would have them. If it really worked manufacturers would put them on special models so they could advertise that it was supercharged.
EDIT: I guess I just have too much idle time on my hands while I wait for all the parts to be installed on my new truck. The lift kit won't be here till the last week in Jan or the first week in Feb, the truspeed is going to be here on Thursday and all the other stuff in my signature is going on this week. In the mean time at least I'll save a bunch of money on gas. (I traded my '97 F250HD CC 460ci for a 2002 Ford Focus for my girlfriend)
Here's the thing. The electric sc won't work because that wee little fan can't "force" air. it can only move air. To get any benefit you need to create pressure, so even if the fan could keep up to even move enough air through the intake, it would have to create pressure. Ie if you put your hand against it, it's going to force air to seep out the sides of your hands. However it probably can't even keep up witht he flow that the engines require, so the engine will be dragging air in witht he fan as a hinderance, and thus blocking airflow.
Think of it this way, if the thing spinning blowing air into a tube, can you put your hand over hte tube and stop the airflow? if so, it will be an obstruction, not a benefit.
I just looked at the link. That little tincan fan blocks 60%+ of the surface area for air to travel. The engine is going to be sucking air in and tear that little fan off and suck it up the intake and blow up your motor.
To be fair, it has been done. On a small engine, the guy used 3 industrial blowers. They were powered by 12 massive battteries in the trunk. Here's a link:
Thomas Knight Turbo Electric Supercharger - Tech Review - Turbo Magazine
Interesting, I read up on that TKT system and it seems like it is designed for small cars but it would probably work just fine in a larger truck like the Excursion. The cool thing about the TKT system is that it is battery powered, so you can get boost when you need it without drawing directly from the engine, therefore there is not HP lose when engaged and it recharges while you are not using it.
At the bottom of the page it says they blew an engine with too much boost because they made it run too lean.
Also, to lean = MAF isn't tracking air properly. They were moving more air than it could read most likely, or they didn't upgrade the injectors so that was the limting factor, or they didn't upgrade the fuel pump so that was hte limiting factor. You'd need double the blowers and double the batteries. Read up on what he spent on all that.
