Jacks?
<input id="gwProxy" type="hidden"><!--Session data--><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
So many uses as well. My wife's 76 when we put it in storage the only access we had to the place was a hole in a fence through an alley. We had to jack up the rear end and push the edge of the truck over moving it a foot at a time till we could roll it into it's final resting place.
Broke my eye bone when the handle snapped back but all in all it worked well.
The one inside the glovebox on my 80 F150 looks almost like that, except they updated the drawing to resemble the newer bodystyle.
The one inside dad's 74, shows the jack location being under the radius arm, after the tapered down area, close to the frame. Sorry, but I can't get the camera to take a pic. My Daughter has it with her.
Ouch....I have seen actual lifting/attachment points for that jack tongue made into bumpers and on rock sliders.
The tongue will fit right into the rear receiver hitch point, but talk about not the best way to lift the whole back end, good to take the weight off to re-bead a tire ect.....
Hmm Never was really into rock crawling myself but for the 74' Since I plan on keeping my heavy duty bumpers I was going to weld pads and attachment point to the frame So I can lift without warping body panels or putting undue stress on the bumpers.
the rear will be similar to this that is on my 93.
Ck out the brackets in the red/orange circles, pay no mind to the type of the vehicle and where it looks like it is. The date is messed up on the camera to.....
Make the brackets out of 3" channel or what ever fits the jack tongue the best and weld them tight, the back ones are connected to the receiver hitch.
I have maxed out a 48' high lift on those points, trying to get those 38's out of a mess. Not my favorite thing to do but.... you can rough up (weld puddles) the flat under edge to give the jack tongue something to bite into other than the end of the bracket.
Sorry the nerf bar/rock slider brackets was a later on project. A piece of 3" pipe works well there if you are adding it to a already attached set of rock sliders. Close to the front or back tire so you do not have a catch point to get you too hung up, or incorporate the hole inside the tube itself.
hi lift/ handy man/ jaw breaker. I've never had a problem with them. Except the one time when some felonious jerk swiped the jack. I had to limp it off the road block it with a ROCK and dig! where there's a will as they say. Fun hint for 4X4's, make a cup, that lifts the axle from the hub. ALWAYS block the axle up, so lifting from the hub doesn't cause problems or get in the way, and Nothing short of being hit by another vehicle will drop the truck on you. Just recently lost another guy, crushed by a truck. IT ONLY TAKES 5 MINUTES, SO IT'S NOT WORTH THE RISK!!!!!!!!
Handyman high lift farm jack. Been riding in the back of my various trucks for 25 years. A little oil dribbled on the mechanism keeps it working good, but even a few drops from the dipstick will work in a pinch. Never put your hand on the top end of a Handyman jack while you're using it. Once saw a guy get his hand pinched between the jack and the truck when the truck rolled. Good thing we were around to help him get loose. It would have been a long day for him otherwise. . .
#28
Pheww sure it didn't look to pretty there paul.
My problem was when we were jacking the truck up it reached the point right about where it was supposed to tip I was giving it one more for luck but before the handle locked back up my buddy pushed the truck shifting the weight on the jack and it threw the handle back to my face broke that little bone on the side of my eye clear in half fun times.
#29
on
Very handy and safe. Powerbuilt® 3 Ton Jack & Jack Stand - 1160455 | Tractor Supply Company
#30
