2006 manual lockout hubs
Here is the Rugged Ridge locking hub description:
Rugged Ridge Locking Hubs
Knee deep in the mud with a failed automatic hub and a disabled vehicle? The only way to repair it is to replace it. The question is, with what? Factory automatic hubs have a history of failing when you need them the most. A damaged hub will render your 4x4 useless and leave you stranded. Wish you could swap your vulnerable automataic hubs to a set of manual locking hubs? Rugged Ridge has heard your plea. Rugged Ridge Manual Locking Hubs are unanimously recognized as the world's toughest hubs by our thousands of satisfied customers worldwide. Brute strength matters, that is why the bodies of our hubs are crafted from impact resistant nodular iron, and feature a corrosion resistant die cast aluminum cap. Our hubs deliver better 4WD performance when locked and improved fuel economy in 2WD when unlocked, than automatic hubs. Purchasing a set of premium manual hubs is more cost effective than servicing your worn factory hubs. with the money you save you'll be able to carry a spare set, not that you'll need them. Sure you have to get out of the cab to lock the hubs, but unlike automatic hubs, you won't have to wait until you lose traction for your four-wheel drive to engage.
4x4 JEEP/TRUCK LOCKING/LOCK OUT HUBS by RUGGED RIDGE
Rugged Ridge does offer their locking hubs for the 2006-2008 Super Duty's (see link below). The price for the 2006 Super Duty is $274.95 with free shipping.
Driveline: Rugged Ridge Locking Hub - Rugged Ridge & Omix-Ada Accessories - RuggedRidgeSales.com
The '05 and up hubs are much better. But that doesn't mean they are perfect. Most of the time the problem with these is a vacuum leak outside of the hub. In the hoses, the pump, or most commonly the vacuum solenoid valve. These axles themselves don't often leak. Seal kits for the hubs are cheap and easy to install.
For an '05 and up, I would recommend you fix the OEM system. Unless you prove it is leaking around the axles, in which case the cost of repair might not be worth it.
For my '06, seal kits on the hubs and replacing the valve fixed me up nicely. YMMV.
No idea as to trouble. I'm about to start the conversion of my '03 F 250 2wd to 4 wd. I've bought an '06 rollover that has ESOF as a donor truck. In my research I found out that the ESOF was a major issue for conversion, so I've bought a manual transfer case to just avoid it all together. Now I'm looking at the next problem on down the line which is the hubs. I'm sure others will come up, but this is the next one on the list.
Jeff's has them (Warn's).
D60 Warn Premium 35 Spline Hubs
Here is the Warn Ind application chart.
Warn Industries - 4WD Premium Hubs
I'm very sure those will not fit an '05 and up Superduty.
From: Lowry, Heidi [mailto:LowryH@Warn.com] On Behalf Of Warn Customer Service
Sent: Friday, March 06, 2009 11:27 AM
To: a1saine@adelphia.net
Subject: RE: Support: Part # 62672
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Andrew,<o></o>
<o> </o>
Thank you for your interest in Warn products. However, PN 62672 will not work with your vehicle as Warn does not offer an aftermarket hublock for the '05+ Super Duty. The Ford Super Duty truck has a hybrid auto/manual hublock installed from the factory. The wheel ends are disconnected until they are manually locked or shifted into 4WD. <o></o>
<o> </o>
Regards,<o></o>
<o></o>
Heidi Lowry<o></o>
Warn Industries<o></o>
Customer Service
Yeah, I contacted Warn Industries about those hubs a few years ago... they will not work on the 2005 and up Super Duty. Here is their response:
<HR align=center SIZE=2 width="100%">
Andrew,<o></o>
<o> </o>
<o> </o>
Regards,<o></o>
<o></o>
Heidi Lowry<o></o>
Customer Service
Andrew,<o></o>
<o> </o>
<o> </o>
Regards,<o></o>
<o></o>
Heidi Lowry<o></o>
Customer Service
Is there a reason why you bought a new transfer case as opposed to remoing the motor and buying the linkage. I thought I read on here that the linkage would bolt right on and the only thing that had to be done was removing the plug in the floor, buy the handle, boot and linkage and your all set.
This was a while ago and my mind is shot so I could be all wrong. I wish I ordered my truck with the manual T-case but the wife drives it somethines and I wanted it to be easy for her to use if needed. But I have to say at just about 68k, I havent had a problem with my auto 4wd system...yet.
Sarge
Sarge
Sarge
Sarge
Last edited by DieselVol; 01-15-2012 at 05:26 PM. Reason: Additional info: They are both called part number 7A195 by Ford, but they get an additional $600 for the automatic.
I got info from this and other sites that suggested that the entire transfer case had to be changed. We'll need others with more knowledge to tell us which is right. However, the transfer case itself is a separate part number from all of the linkage parts and there are 2 different part numbers for the manual (NV271) and the auto (NV273). I'm pretty sure I've done the right thing by buying a manual transfer case.
Sarge
#28
#29
Rugged Ridge does make a hub for the 2005-2008 Super Duties but only those with a Dana 70 front axle. The Part# is OMX15001.97 which is also listed for the 1999-2004 Super Duties with a Dana 70 front axle.
