Fuel gauge not working.
#61
Also, here is a link to a wiring diagram for a '74. You'll need this to trace through the circuit.
http://fordification.net/tech/images...aster_3of8.jpg
You can see the resistance wire at the top (BLACK with GREEN stripe). The resistance value is shown as a lumped element in the second quarter from the right at the top. On most early model Fords, the resistor wire is crimped together at the cluster connector with a short length of dummy wire because the gauge of the resistance wire itself is too thin for most crimp terminals. This should make it easy to spot in the cluster connector.
The ICVR and gauges are shown toward the left.
#62
Ok heres what I have gathered from my multi-meter. I did a continuity test on the ORANGE wire that goes to the sending unit and the meter gave an audible tone as it did from that wire and every wire to the cluster. After I did that, I set the meter to voltage and started testing everything. The ICVR is in good working order. At the yellow pigtail I have 12v and the ORANGE wire at the sending unit I have 12v. I then set the meter to ohms it read .0355 and I probably have a quarter tank more or less.
So, what next?
So, what next?
#70
#71
