Anafiel's Podunk Man-Cave Project
#76
Good luck finding materials for your roof,,I am always looking for used tin roofing for my wood sheds and never find any..I did come across a sign saying free wood last summer so I stopped in expecting some firewood,,,Got 15 sheets 3/8 plywood!
I do some painting in my garage so the woodstove is airtight, WETT certified and 18" off the ground,,totally up to snuff to keep my insurance company happy.I was out see a shop being built some years ago,,the guy used uniformed sized pallets to do all the walls of a 28x40 shop with 12' walls,just fastened them together,,now that was clever! Our company has 60 pallets a day sent to the front of yard for anyone to pickup free.
http://www.flickr.com/photos/2283289...in/photostream
#77
Making a little progress.
The goat shelter was up against the side of the lean-to, making it hard to get to that side to repair it, so I opened up 1-1/2 acres on the side of our property where there was another shelter and moved them there. Had to run a couple hundred feet of new fence and posts, but the goats are happy to have new fodder.
Cleaned up a bit behind the cave, and loaded up the truck for another run to the dump.
Materials are slow coming, but look what I got this morning! 10 lightly used rafters!!! They are all completely solid. The pics show mud where they were laying on the ground, but there is absolutely no damage. Got 5 of each, same rise.
Do I see another building in the making? Maybe I can convince my wife into letting me build her a "Garden Shed", buy a little extra materials, and use the leftovers for my cave...
How deep of a shed can I build with 5 sets of rafters like this? Looks like I can get 10-11' wide, but how much cheating can I do with it's depth with only 5 sets like you see here?
Also got some good solid scrap, useful maybe for gable end studs and collar ties?
#78
Good work, and lots thereof. Moving the goats and carrying off the junk was an exercise, but well worth it I'm sure.
On the truss situation, while I'm in no way qualified to answer as I've never used corrugated roofing - which is what I'm guessing you are planning. What span is in your buildings at present?
#79
If I use the trusses to start a new building, I'll just cover it with OSB or plywood and paint it until I can find/buy some shingle for it.
I don't think I've ever posted the dimensions of the cave yet. Let me go measure it now...
#81
#82
The cave is bigger now than whatever I could build with those trusses. I want to continue to go the cave route and continue on to repair it.
I was just wondering what size building I could get away with with those trusses. Some kind of garden shed for my wife's tools and light storage...can never have too much storage. (Good for truck hoods and fenders )
#84
Well spotted, Jim. Didn't see the tails, or the lack thereof. And, 8' is the depth you should go with just those trusses. As said earlier, any more and you will have sagging. In fact, you may have some at 2', but since it is a shed it shouldn't be that big of an issue. Or, go with thicker OSB.
#87
#88
There's no way a shallow, halved, 2x4 truss is going to support 4' OC Bruno.
Maybe you never get hail, rain or snow there in Oklahoma.
But a 24' long 2x4 is nothing more than a wet noodle.
You'd only need 1 square of asphalt shingles to cover 80 square feet (8x10) ,$50 ??? plus ridge and starters...
#89
30ga utility corrugated wouldn't stress the roof much, right? We never get much more than 1-2" of snow, if ever. Or am I asking for trouble with a gauge that light??
Would the braces between the trusses hold it up under conditions like that? Surly though, I don't want the thing to fall on my noggin during a heavy rain...
Just asking... I don't know these things.
#90
It is a good question. I have stood on 8'-2"x4"'s laying flat and they hold my 260lb butt. So if they were strong side up like your trusses will be then I would imagine it could hold quite a bit of weight. You culd space them in closer if you are worried about it. I would think by the time you bought roof decking, felt paper, shingles and nails it would cost more than some 2x4's,roof pans and some nails with washers.
Too bad you arent a lot closer to here. I have a buddy that has a big sheet metal shop. Anytime I need some metal roofing material I just go get it out of his scrap pile. Sometimes it is shorter than what I need or multiple colors. However, you can use short panels you just have to overlap them correctly. Different colors are easily remedied with some cheap paint.
