mud truck welding 9" rear
I have an 86 f150 4x4 with a 9" rear, is it okay to weld the rear up? trail rig only, actually doesnt even see that much trail as much as it does straight line mud bog racing. Running 33" mud tires. thanks!
Would consider a mini spool but i have never taken a diff apart and kinda scared to do so...
Received 3,107 Likes
on
A D60 is not what we are talking about.
And I have broke pins in D44s
The mini spool is smaller in diameter than the case, allowing a gap between the mini and the case. That applys greater leverage on the cross pin than a welded rear would.
My mind will not be changed. And my experiance has proven that in a 9 inch rear a welded diff with 2 cross pins holds up better than a mini spool and even a full spool. (Yes I have broke one of them in half)
