Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > EcoBoost (3.5L, 2.0L)
Sign in using an external account
Register Forgot Password?
EcoBoost (3.5L, 2.0L) 3.5L Twin Turbo EcoBoost V6 and 2.0L I4 EcoBoost Engines
  #76 (permalink)
Old 04-19-2012, 07:10 PM
jeffdoerr jeffdoerr is offline
Garage is empty, add now
jeffdoerr is starting off with a positive reputation.
my truck also did the bogging down, sputter, backfire pop type of thing. One time. It was bad, check engine light came on, but then cleared up in a mile or so and has never done it since. Took to the dealer, and no code was found, but this was the same dealer that did nothing about my brakes. So far so good, but my mileage sucks. i drive it like an old man and barely get 17, usually 16.5-16.8
Really disappointed with mileage. The v8 F150 i drive for work gets 18 and didnt cost a premium for the EB option.
__________________
[b]11 F150 CC Lariat 4x4 Ecoboost 275/55R20 3.31 Axle White platinum metallic-
[b]12 Edge Sport FWD 22's and White Platinum paint
[b]05 FTL M2 plain old white -
  #77 (permalink)
Old 04-19-2012, 08:10 PM
Greg B Greg B is offline
Greg B is gaining momentum as a positive member of FTE.Greg B is gaining momentum as a positive member of FTE.
It could be the condensation settling in the bottom of the intercooler that has been talked about. I wonder if a larger intercooler that has both the inlet and outlet pipes at the top wouldn't solve the problem.
  #78 (permalink)
Old 04-20-2012, 09:35 AM
al704 al704 is offline
al704 is starting off with a positive reputation.
here's my failure story
While pulling a trailer from Pa to Fl, cruising at 70mph pushed pedal to the floor to pass and the engine lost power and wouldn't maintain speed. Left off the pedal and the truck felt was going over rumble strips for several seconds and then smoothed out and ran fine, this happend 4 times in 2300 miles. The last time the check engine light flashed and than stayed on, called my dealer from the road and made an appointment so I could drop it off as as soon as I returned home. The left catalytic converter was plugged. My question to the service manager was..... the truck has 3500 miles on it so there must be something going on that caused it to plug up in such a short amount of time. His reply was....I thought it was odd too!!! So off I go with a new cat wondering if it is going to happen again of if the right cat will go next. WTF
  #79 (permalink)
Old 04-20-2012, 09:38 AM
Bat-Masterson's Avatar
Bat-Masterson Bat-Masterson is offline
Bat-Masterson is starting off with a positive reputation.
I took mine in today, and I have a great dealer was not there more then 5 mintes and the mechanic came and got me and said lets go for a ride, he already had the computer hooked up to the truck and off we went.
We drove 50 miles trying to make it bog down, bet we tried 50 times. I told him it only did it a few times to me, but since it did not throw a code not much he could do and since he only gets paid finding something wrong he was trying very hard.
When we got back and he hooked back to the internet there was one calibration upgrade so he downloaded it to my truck, truck runs great and gets great mileage so until it throws a code and it might not do it again I am not worrying about it.
He did tell me if I happen to touch the brake will pressing on the gas peddle it will stop the truck from accelerating, I know when I had this problem i was not touching the brake peddle, but on the way home today from the dealer I tried it and it does I was accelerating and I just touched the brake a little and the truck started to slow down quick with no accelerating at all even that I was still pressing the gas.
What are the old people going to that ride the brake and the gas at the same time.
Just a update after they flashed my truck and I went home and since they have to to it with the keys on and the truck not running, it looks like my battery lost it charge and now every time I start it it says low battery and every time I shut it off it says on the radio shutting off to save battery.
they told me to bring it back Sat and they would see if the Flash did something or if I need a new battery
  #80 (permalink)
Old 04-23-2012, 09:31 AM
redford's Avatar
redford redford is offline
2007 Ford F-250
redford is a splendid one to beholdredford is a splendid one to beholdredford is a splendid one to beholdredford is a splendid one to beholdredford is a splendid one to beholdredford is a splendid one to beholdredford is a splendid one to behold
Quote:
Might just be a batch of bad converters.
A few years back I used to drive a 1995 F-150. It developed a problem just like this. Would idle perfect, cruise around town just fine, but any time I had to lean into the throttle (like entering a freeway or climbing a hill) it would slow down. The more you pushed down on the throttle, the slower it would go, plus it would shudder, buck, pop, snort and shimmy.
I replaced every sensor I could think of. I took it to the dealer 4 times hoping they had an answer. No codes were ever recorded. On the 5th trip to the dealer, a technician (acting on a hunch) unbolted the exhaust in front of the catalytic converter and went for a drive. All of the lost power was suddenly restored.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Retired Master Sergeant
  #81 (permalink)
Old 04-23-2012, 09:47 PM
kw5413's Avatar
kw5413 kw5413 is online now
Fortune Favors The Brave
2010 Lincoln MKT
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
My MKT has stuttered a couple of times but, cleared its throat and mved out.
I just did a day trip to Houston and back today. Over 525 miles round trip in a couple of spots I had the opportunity to "hit it" at high speed (there apparently is no speed limiter on the MKT). The "girls" took a deep breath....then it was like hitting warp speed. No hesitation from 80 to 110.
I am a product of the muscle car era and this sweet heart is the fastest most responsive vehicle I have ever owned.
__________________
"You're doing a lot of choppin', but no chips are flyin'." - Foghorn Leghorn
"I am not afraid of death. It is the process of dying that bothers me."
Book of kw5413, Chapter 2012 Verse 05:17
Tags
2012, 68, boost, coyote, eco, ecoboost, engine, f150, failure, failures, ford, problems, shaking, stall, truck, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
