My ultra low budget 6.0 coolant filter
This happened by accident. I generally avoid walmart like the plague but I had to go there to get a Christmas gift for my son. While I was there i stumbled into the filter section and the light came on. So I'm out about $50 bucks give or take.
I really don't want to take the time to cut my filter open so this instantly fixes that issue. It has a valve built in so it fixes that issue as well. The filters can be obtained for about $2.50 ea so I can change it one a week if I want.
This might not fit if you have a hood liner.
If anyone is thinking of trying this you must use silicone grease on the filter o-ring as it's really designed for higher pressure. Also plenty of teflon tape on the fittings. I had leaks the first try using pipe dope. It doesn't leak now. Cheers
Yea i would watch that thing closely , what Benny said about the heat. The paper inside don't want it coming apart and going though your cooling system and then not making it though the oil cooler. By the way did you look on the instructions and see if it can be hooked up to the hot water heater or just on cold side, that might give you some insite on its hot water ability .
Not sure about psd engines but cat coolant filters are as much about preventing electrolysis on the cooling side with magnesiem in the filters as filtering stuff out of the coolant. Not positive about that though, i run 5 big trucks and thats the main reason for coolant filters is to slow down the electrolysis that eats through the block of the engine
I do have a super magnet taped onto the bottom of the lower radiator hose though.
Magnets will not help and aren't really what he's talking about. He's talking about using sacrificial anodes (Mg is for fresh water, Zn for salt) in the cooling system to prevent corrosion.
Any Update on Longevity
I know this is an EXTREMELY OLD thread, but I was wondering if anybody knew of an update on this. If it lasted, or if the OP had problems with it. I sell these water filters at my shop. Just wondering because of how terrible it looks, but interesting to see if it held up.
When I was with the fleet we started useing a similar plastic houseing whole house filter. Placed inline between the radiator inlet and thermostat houseing. 215 deg. is the most we let ours system get. Much more than that the houseing would begin to distort a little and leak a bit. We would remove them after flushing. Tried leaving a couple on but chickened out after a year and removed them too.
They do not sell the ones we used anymore around here.
What micron rating are you using? The smallest we sell at our shop is 5 micron. Also, why did you go stainless on the housing?
