Where to Find Heads?
While aftermarket heads are a better HP option a set of stock GT40 heads may be all you need depending on what your goals are? If you can find a set of used heads in the $275-$400 range and you are only looking to improve performance a bit then the GT40 may be the best/cheapest option. A mild port-n-polish and milling of these heads will net you 20-30 HP over stock non-GT Windsor heads, Throw in a cam swap and then you will really wake up the engine!
tnnuke
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-21-2009 07:31 PM
ford390gashog
08-23-2004 01:35 PM
