Guys I should know this but can't think of what it is, CCK, can you help?
Chet
CCK is the "Cross Connect Kit", formerly known as "Cackle Cure Kit", which was a fuel return system by Dino Fuel Alternatives.
Designed to open up the dead head fuel rails. I installed it a couple years before Clay came out with the FRx.
Joey I see you started this around 12/30/11, where do you stand on the build now?
The machine shop says they will be done Thursday(1/19/12)..Motor is out of the truck,so,I am hoping to be running Saturday,maybe as late as tuesday...I will post more pictures ASAP...
Did you use the Terminator HPOP and 38r from your 03 engine? Or did you get new?
using the 38r off the 03 and a new dual Terminator HPOP setup...I know its overkill on the stage 2HO injectors but it can be controlled and gives me room to move forward if i wish...
and actually,this build has been going on sense late September,I just didn't post up until late December..
