What oil weight to run in 5.0?
I have a 1995 E150 van with the 5.0 and the owners manual is confusing to me. First it recommends 5w-30 then goes to say that in this engine the 10w-30 weight should be run. I currently put the Motorcraft 5w-30 semi synthetic blend in it. I live in Chicago where in the winter can get into the single digit temps. Opinions?
Thanks.
Really you can run heavier weights like that in this motor? I don't like mixing oils and I don't think Motorcraft sells a 40 or 50 weight. Motor has 121k miles.
LA_BigRed
11-30-2004 05:30 PM
