'78 and '79 Power steering fix!
Old 02-25-2012, 08:14 PM
crazy96863's Avatar
crazy96863
crazy96863 is offline
@ earthquake... Just wondering what pump your running?
  #32
Old 02-25-2012, 08:31 PM
justforkicks's Avatar
justforkicks
justforkicks is offline
Originally Posted by fordtrucknut
It would be interesting to see if Ford ever had a TSB out on this problem. For those not aware of what a TSB is...It stands for Technical Service Bulletin.
Ford actually had a recall on 78/79 steering gearboxes on the F-150 4x4's. My dad's steering had the same problem from just a few days after driving his off the lot (78 F-150 4x4, identical truck to earthquake's, motor, paint and all) back in November of 77.
  #33
Old 02-25-2012, 09:54 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
I tried the saginaw pump, but after I figured out what the problem was, I changed back to the stock pump and it's working just fine.
  #34
Old 02-25-2012, 10:12 PM
J ballan's Avatar
J ballan
J ballan is offline
Where did you get the Saginaw? Did they come stock on some dent sides? Thanks
  #35
Old 02-25-2012, 10:44 PM
earthquake68
I got it off of an '84 Chevy truck. I made the brackets to put it on my 300 six.
  #36
Old 07-16-2012, 10:17 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
I'm bringin this back from the dead, but couldn't you just drill and tap the top of the box and use that as a bleeder? Or I guess, not as a bleeder, but to top off the fluid?
  #37
Old 07-16-2012, 10:42 PM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
LITTLE BLACK TRUCK is offline
Im worried now cause I was gonna change to power steering and I want my steering to work!! I have a manual steering box now but a new manual box is twice as much as a power steering box!
  #38
Old 07-16-2012, 11:02 PM
hasteranger
I put my 35x16" wide tires on and steering is impossible but my ps fluid is low and my box is groaning. so I'm gonna add fluid and try bleeding it. I know its not gonna be easy steering while stopped but its literally impossible right now!
  #39
Old 07-17-2012, 09:13 AM
earthquake68
I have 33 x 12.50 X15's on my truck and steering with it stopped is barely different than steering with it moving. A good pump and no air in the box will be the cure.
As far as putting a bleeder in, with my luck, I'd drill into something important. It may be a pain to get going, but once it is, it stays working for a LONG time. I'm on 6 months with ZERO issues. (knock on wood) I didn't think it was worth the risk to modify the box. Once it's properly bled, you're done.
  #40
Old 06-20-2013, 11:46 PM
ROKRAWL's Avatar
ROKRAWL
ROKRAWL is offline
Ok. So I read this post a few months ago and tried the method on post 20. Seemed to work fine, however when it cooled down to below freezing the steering pump would whine until it warmed up a bit. No problems steering but the whine would wake up the neighbors. It started warming up and the whine disappeared. A couple weeks ago after a highway trip, I lost power steering for about 15 minutes. Came back and worked fine for about 2 weeks. This past weekend, on another highway trip I lost power steering again. It didn't come back until randomly one afternoon I had power steering for like 5 minutes then lost it again. Tonight, I used both the method mentioned in the first post, followed by the method in post 20. Steering seemed to work fine during initial 5 minutes of test drive then started to act up. no sounds just started to feel hard to steer. I let it sit for about an hour, checked the fluid level and went out for another test drive. I noticed during this ride the power steering seems to do much better at higher rpms. When coasting through a turn it would start to tighten up so I would shift to neutral rev it up and the steering would get looser. Anyone know what might be the problem? I don't want to just start throwing parts at it but I have a feeling something is broken. What do you guys think?
  #41
Old 06-21-2013, 12:29 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Got a Ford pump? Then read this: http://www.stangerssite.com/HowItWorksFordPump.html
Regardless, it sounds like the pump is going south.
  #42
Old 06-21-2013, 12:38 AM
ROKRAWL's Avatar
ROKRAWL
ROKRAWL is offline
Awesome info. Thanks.
  #43
Old 06-21-2013, 09:10 AM
J ballan's Avatar
J ballan
J ballan is offline
Mine was the same way and I got fed up with it and installed a Saginaw pump. After I started it with the new pump I instantly had perfect power steering with zero bleeding. Best mod I've done so far!
  #44
Old 09-20-2013, 05:45 PM
Andyf150xlt's Avatar
Andyf150xlt
Andyf150xlt is offline
Im having a problem with mine i have a 79 f150 4x4 and was wheeling and all my fluid blue out the pitman arm seal on the steering box just rebuilt it all new seals and while bleeding it, it blew the new seal could that have been because of air in the system im getting ready to replace the seal again and would like it to work this time. If you have any info please share it thanks.
  #45
Old 09-20-2013, 09:58 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
After reading this thread, i think i will just keep adding ps fluid....
Quick Reply: '78 and '79 Power steering fix!
