F1 stock angle?
Old 12-18-2011, 12:46 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
F1 stock angle?
I've got everything torn apart, otherwise I'd measure myself, but can anyone tell me the angle of the frame when a stock suspension and wheels are used on level ground? particularly at the center where the frame is an even 6". Just need it as a baseline.
Old 12-18-2011, 01:46 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
havi, have you checked Earls World, i think he moved off site , but if i remember he had alot of demsional info, a good resource as you probably already know. Just a thought. Happy holidays
Old 12-18-2011, 01:54 PM
Doc's Avatar
Doc
Doc is offline
Havi, I will get you the measurement when I get home this evening. I even know where my angle finder is which is a miracle!
Old 12-18-2011, 04:01 PM
Doc's Avatar
Doc
Doc is offline
About 2 degrees (front lower than rear obviousy) in the center of the truck on both sides.
Old 12-18-2011, 05:17 PM
havi's Avatar
havi
havi is offline
Thanks, Doc!
Old 12-18-2011, 06:08 PM
havi's Avatar
havi
havi is offline
I think I need a couple more measurements: On level ground, can someone measure from the ground to centerline of rearward hanger hole, and the ground to centerline of front lower shackle hole?
So far I have: hanger hole to front hanger hole is 35.38". from the bottom of the frame in a line, it is -2.38" at back spring hanger, 1.75" front hanger hole, but the shackle drop 2.75" so it hangs down -1" below frame. The frame itself is 6" high at the back hanger, but only 3.5" at the front hole, but a level placed on the bottom of the frame will show the very front comes down and meets the same line as the 6" section. According to Doc there is a 2 degree angle. By my calculations, the slope would 1" in 35.38" if the frame was level, but it is not. I'm trying to figure out where to drill the holes for mounting the springs and axle to a straight piece of rectangle tube yet keep everything within spec of caster for a baseline. (If the tube ends up not being level, then I can shim the beam axle, but need a baseline)
Old 12-18-2011, 07:09 PM
Doc's Avatar
Doc
Doc is offline
Okay. I THINK I know what measurements you need. This is where the measurements will vary because of tire size differences. I am running 215/85/16 radials. But I think you're more interested in using the measurements to figure out geometries than the shear measurements themselves. Right? If you can show us a quick pic of the measurements you want, it would be helpful.
Plus I would feel more comfortable if somebody else chimes in with a frame angle measurement. Theirs may fluctuate slightly.
Old 12-18-2011, 07:12 PM
havi's Avatar
havi
havi is offline
Doc, the tire size itself isn't as much a factor as it is knowing the difference between the front and back.
Old 12-18-2011, 07:59 PM
Doc's Avatar
Doc
Doc is offline
Okay dude, I went and measured. Keep in mind my springs are original and "tired" (but complete and unbroken). All measurements are from the center grease fittings in the shackle pins to the floor. Starting from the front of the truck and going to the back:
Front spring, front upper through the frame - 15 1/2"
Front spring, front lower through the shackle - 13 1/4"
Front spring, rear through the frame - 12 3/4"
Rear spring, front through the frame - 21 1/8"
Rear spring, rear through the frame - 24 1/4"
Rear spring, rear through the shackle - 21 3/4"
Make sense? Hope that helps.
Old 12-18-2011, 08:18 PM
havi's Avatar
havi
havi is offline
Thanks again!
I'd give ya rep points, but it says I have to spread it around first.
My '62 Fairlane is getting the front axle and springs from my spare F1 frame. The front rails are being replaced with a rectangle tube to match the originals, the overall width is within a 1/4", and they will be adjusted that amount to keep the axle and springs intact. The rear hanger is an L bracket which = no adjustment. The front will have to be all of the height adjustment for caster, and if the car has a 2 degree rake, all is good. If not, then shims may be needed.
Old 12-18-2011, 08:49 PM
Doc's Avatar
Doc
Doc is offline
Lol. No problem. Let me know if you need any more measurements. I'd doubt there's 2 trucks anywhere with the exact same measurements.
Old 12-18-2011, 08:55 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Originally Posted by havi
Thanks again!
Got it for you.
Old 12-19-2011, 10:11 AM
jim collins's Avatar
jim collins
jim collins is offline
Thanks again!
What are you building,a 1/4 mile dragster ?
Old 12-19-2011, 10:13 AM
havi's Avatar
havi
havi is offline
Yes! In theory anyway, lol.
Old 12-19-2011, 10:45 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Just sent a couple of views
Quick Reply: F1 stock angle?
