95 Ford Bronco 5.8L parts ?
Im getting some major work done to my bronco. I currently have a oil pan gasket and a rear main that need to be replaced. I was looking at the 1 piece oil pan gasket that bronco graveyard has. Is this a good oil pan gasket and where should I get the rear main gasket/seal from? I wasnt sure if there are certain gaskets or seals to stay away from or any companies that make crap. Also I plan on doin a new water pump & timing chain and which ones are good? And do you guys recomend anything else to get replaced while all this work is getting done. Any help would be greatly appreciated, I just got this truck and with 118 k, I plan on keeping it for a while.
I buy most my parts at Autozone, but that is just me. And I have had my Bronco less than a week, so I am not an authority on them. However, mine needs a rear main seal also, and I plan on getting it at Autozone for $18.36 Oil pan gaskets, I prefer the rubber (neoprene) instead of the cork, but again, that is a personal preference.
Jim
Jim
I use rockauto.com unless I need the part that day. They have a good selection, cheap prices, and fast shipping. As far as other work that needs to be done. If you don't know when fluids (trans, rear diff. etc) were changed last I would have them done. Chances are like when I bought my Bronco it had never been done. I would then look into plugs, plug wires, dist. cap and rotor. Welcome
Casey Wright
1978 - 1996 Big Bronco
03-08-2016 07:30 PM
