Tinman's '51 Cabover lowbuck build
#437
#438
3 years!
I just realized it's been 3 years since I started this build thread......wow, time flies. I went back and read through the whole thing, what a project!
Been working on the running boards. I ended up cutting a bunch off the front edge to get the right length. Also had to extend the brackets a bit. Still need to make the fillers/skirts and trim the fender bottoms.
Also can't decide on battery placement, the OE had it on the right board with a cover as a step. I don't have the cover, so was thinking about hiding the battery behind the skirt towards the back. But then I still need to make a step.....dunno yet.
Also removed the leaking water pump....
#442
Still playing with running boards......got the right one cut and fitted, trimmed the fender bottom. Decided to put the battery behind the skirt, so I had to build a tray....will access from the rear. Now I have to build a step..
Need to finish the other side and get some sheet metal for the skirts
#443
Received 4,195 Likes
on
#444
#445
#446
#447
#449
Perfection? Not even....but thank you Jim(and everyone) for your kind words.
Just trying to make it functional and somewhat pleasing to the eye. I love doing fab work, but this build is taking too long. I'm burning out....
#450
