New Carb
Reason for the negligible difference in fuel consumption is likely that the CFM requirements of a big engine will result in a undersized carb running more throttle opening, running on the secondaries, and possibly on further enrichment as well in scenarios that a properly sized carb would not be into the secondaries or any enrichment circuits. I can say for certain that when switching from a 600 VS to a 750 DP that to accelerate brisky or maintain speed I had significantly less throttle opening with the 750.
Cadunkle, that does make sense. Like having too small a furnace for your home. You think you're saving money but you're more likely to have a higher heating bill. Better to have too much than not enough. Makes me kind of curious why they put a 600cfm carb on the truck to begin with though. If I notice that I have to shift down during a load I'll probably upgrade to a 750. That won't be until early next year when I start pulling the dirt track car again.
Having said that, my issues with Holley's, or Holley-designed/built Autolites, have to do with what I consider poor engineering in three areas:
- Power Valve: How many times on here have we seen people complain about blown power valves? Lots! I, too, have had the same problem many times over. But basically none of the other carbs we discuss on here have that problem-prone method of fuel enrichment, having gone to metering rods many, many years ago - and that includes the 2150. Metering rods don't blow and they and/or their springs are easily swapped by pulling the top which, by the way, doesn't spill gas all over the engine when you pull it. And, I realize it is possible to add a check valve to prevent the power valve from blowing, but that is an after-market fix to a well-know engineering problem.
- Accelerator Pump: Yes, all automotive carbs need an accelerator pump, but a diaphragm pump like Holley as chosen for most of their carbs is another problem waiting to happen. How many times have I had to pull the carb to tighten the screws because they backed out and it is leaking, or to replace the diaphragm because it split!? The piston-style pump that the other manufacturers went to long ago may wear and slowly lose its volume, but they don't fail catastrophically.
I believe it is extremely rare for an accelerator pump failure to result in an external fuel leak. Accelerator pump can and will fail with age and use. I have had to rebuild Quadrajets with AFB style pump that had failed. I don't believe there is much difference in failure rate though Holley pumps look and feel more durable to me. Beyond that, a Holley accelerator pump is far more tunable than an AFB style pump. You can have options for accelerator pump size, discharge, duration, and curve which can be customized. AFB style carbs give you less tuning options for the accelerator pump circuit which will result in more wasted fuel on the accelerator pump circuit.
- Bowl Gaskets: I've had the gaskets leak - both from warped carb bodies as well as from the gas in the bowl going away (power valve!), and then they shrink and leak seriously. And, when you do want to change something in the carb, like the inevitable part replacement or tuning, you'll spill gas all over the manifold. No one else builds a carb that way as they use a metal casting to hold the gas in.
The most common reason I see a Holley leaking externally is a stuck float or crud in the needle and seat resulting in fuel flowing freely out the vents. In a marine or off road application with bowls vented down the venturi this result in a severe flooding condition but no external fuel leaks. In a standard automotive application some fuel will leak down the venturi and some will leak out onto the intake, as an external fuel leak. AFB style carbs will behave similarly, though most fuel should be contained down the venturi, similar to J vent tubes on a Holley or connecting the vents with vacuum hose that is slotted for venting.
I consider the Holleys an antiquated design with serious problems that others solved long ago. Yes, they can be made to work well as they are tunable like all the other carbs. But, I believe the ability to change out metering rods and springs on top of the jets provides more control than Holley provides with power valve and jets.
All the issues you mentioned are either non-issues due to either user error or being resolved long ago. Holley is a far more adjustable and tunable design than teh AFB style carb. This is why they are used in high power and race applications that demand maximum power from a given engine. There is simply more adjustment and tunability on all circuits. Where the AFB has an advantage over Holley is the metering rods. This allows a smoother transition to enrichment and not an all or nothing approach. On a properly tuned Holley, you are rarely into the enrichment circuit though, so I do not see this as a worthwhile benefit of the AFB design when considering the many advantages of a Holley over an AFB.
If a more progressive enrichment is desired, there are two stage power valves which will provide two progressive levels of enrichment. I've never had an application that I found this necessary as I've never had to overly enrich the mains to avoid a lean stumble on transition from main to enrichment. Proper single stage power valve sizing has also got me smooth enrichment while avoiding unwanted enrichment while cruising and light acceleration. Regardless, the option is there is a more progressive enrichment is desired. Furthermore, staggering power valve ratings across primary and secondary sides can result in another level of progression in enrichment, particularly if running two two stage power valves with different ratings on primary and secondary sides. Again, I've never personally encountered a situation where this was necessary or desirable, but it is possible to do a "4 stage" enrichment circuit on a Holley.
Holley carbs simply beat out AFB style carb on getting the most power from a given engine, and will not sacrifice any fuel economy to do so. I don't see any advantage to running an AFB style carb. If you want smoother transition between circuits, maximum tunability, and greater efficiency you need to look at Quadrajets (which will leave power on the table compared to Holley) or better yet Webers. AFB is not the answer. Please keep in mind, I'm not bashing AFB style carbs. They work alright, they meter fuel and do a good job of it. Holley just does it better... and of course others do it better than Holley, but are far more complex for your average Joe to work with, and in the case of Weber carbs, far more expensive as well.
Another part of the reason for going with a smaller carb could be to increase intake charge velocity in an attempt to achieve better atomization. This is likely as the carbs on tehse trucks, if I recall correctly, had annular boosters. The annular boosters support this theory as they will atomize fuel better than straight or dog leg boosters. The velocity is a non-issue as with 460 cubes you have plenty of intake charge velocity with a 750 CFM carb. It's not until larger carbs are required that intake charge velocity will noticeably suffer at lower RPM, but at that point you have enough cam that low RPM will not be significantly affected or even something you care about, as you want max power at the higher RPM as you approach peak.
Aside from that, a smaller carb is cheaper, as is using a 4160 type setup instead of a proper 4150. Or it could have been a misguided attempt to regain some MPG that was lost on the emissions equipment. Another factor I'm not 100% on is the incoming CFM of exhaust gas on these EGR systems. That is contributing to intake charge flow though it is inert and not producing power, in fact hurting power. This may contribute to a lower carb CFM requirement at cruise when EGR is flowing, but would not reduce CFM requirement of clean fresh air/fuel mixture at high load low throttle conditions or high load high RPM conditions.
Basically my supposition for the use of an undersized carb is emissions and cost related. Prior to the smog era junk Ford was running 700 or 735 CFM carbs on 428s and 429s.
Cadunkle - Always tough to go first as you give it your best shot and the other guy has the time to sit back and come up with good answers, which you've done. However, you didn't address spilling fuel all over the intake when you pull the bowls.
I will admit that my "love" of Holleys started in '69 when I bought a new Super Bee that had one on it. That carb was a piece of junk from the factory as it had warped everything, and that wasn't unusual for them in that era. And in that day they came with "old nasty cork gaskets" which would not seal on the out-of-the-box warped bodies. But, I guess if you are working with inferior products it is understandable that you naturally have to machine them flat just to put a kit in them. Silly me, I'd grown up with Carters and Rochesters and wasn't used to having to finish the manufacturer's work.
And, as Bill Vose pointed out, the Mopars of that era were prone to backfire through the carb due to their emissions package and not user error, and you could count on losing the power valve when they did. But, I wasn't aware Holley finally addressed the flaw in their design with a check valve since I gave up on their product long ago. However, I doubt the many guys on this forum who've posted about their blown power valves would agree that it is a "non-issue" as you said. The poorly-engineered products are still out there in service and still have the same problem I had with them in the 60's, while the other brand carbs don't have those issues and never did.
I do, however, agree with you that the Holley is capable of getting the last little bit of power out of an engine when tuned by someone who knows what he's doing. So, I think they are a good carb to use on the track.
I also agree with you that the Q-Jet is a better carb than the AFB. In fact, I like it better than the AVS, but would bet on a properly-tuned AVS getting better WOT power than a Q-Jet. However, for street use I prefer the Q-Jet and have considered building one up for my truck. The one I put on my 390 in '72 worked very well.
Wow. That was very well thought out. I've dealt with my factory Holley and can't stand it for all the reasons you've stated. It was never meant to be tuned or adjusted so when I started messing with it everything started to go bad. I've since had to rebuild it twice and finally got it to the point where it will start and idle well after it is warm. It still is extremely rich and I haven't been able to get the mixture just right. Maybe it's my inexpertise that is the issue there. I just know a new carb is in the future and for now its an Edelbrock 1406. I may regret this and I'll definitely let you know the outcome. My next carb may very well be a Holley. Who knows. It's all a matter of preference and application. Like my uncle once told me. Opinions are like ---holes. Everyone has one and they all stink. Lol.
I have used Holley carbs since the 1960s and have never had a problem with blown
power valves or leaking accelerator pumps. They are very tunable and reliable. I have
2 classic muscle cars that both have Holley 4bbls and my 1981 F100 with a 351W also
has a Morocraft-Holley 4180 which runs very well. The afore mentioned cork gaskets
were a pain but the later type gaskets seal well. Most problems with Holley carbs
with warped surfaces are caused by over torquing fuel bowl screws or base plate
screws. I never knew the 1969 Super Bees had Holleys except for the 440 option
with 3 2bbls which were Holleys. I thought the 383s had Carter AVS carbs. But 40
some years is a long time and I could have forgotten and remembered wrong.
Then, one year at the All-Chrysler meet at Carlisle I saw a "survivor" that said 383 Four Bbl, and the engine was turquoise, and no bright exhaust tips. But, it had an AVS! So, I talked with the guy and found he bought the thing new so was 100% sure it was original - except for the carb. Turns out he hated that Holley so put it on the shelf and installed the AVS.
About that time Galen Govier, who is the guru of all things Mopar, wrote a piece in Mopar Muscle that said all '69 Bees had an AVS, bright exhaust tips, etc. So, that got me to wondering about mine and I did some research. Turns out that all auto & A/C Bees got the 330 HP 383, which was the run-of-the-mill 4 bbl engine, while all other Bees got the 335 HP engine with the better cam, the AVS, a windage tray, etc. In fact, I have a copy of the sales literature for that year that actually explains all that if you know what to look for.
Oddly enough, in '68 the 330 HP 383 had the AVS and the 335 HP 383 had a Holley.
#28
#29
Yes, things were "interesting". Why would Chrysler change the Magnum engine from a Holley carb in '68 to a Carter in '69 while doing exactly the opposite on the non-Magnum engine? And, from what I can tell the carbs were basically the same for the two years, meaning that the '68 and '69 Holleys were the same carb as were the Carters. I'm sure there's a reason, but just can't reason it out.
But, the substitution of the 330 HP engine for the 335 when running auto and air does make sense. I'm guessing the cam was too much to maintain the proper idle when loaded with the 727 and that big ole Airtemp compressor. However, they didn't want us to shy away from those money-making accessories so buried the fact that they were swapping the engines in some obtuse wording which only makes sense when you know the answer. And, they were successful as even Govier hadn't figured it out.
#30
What I do to avoid this being a problem, mess, or fire hazard is take a cap from a rattle can and place it under one of the lower bowl screws. Pull the screw and almost all the fuel drains into the cap, then pour back in the tank or once you're done you can pour it down the carb vents so you have fuel right away. I also place a couple rags under the bowl for the last dribble of gas that comes out when you pull the bowl and metering block off. I don't have problems with fuel touching my intake or a messy gas spill. It still sucks though. I particularly dislike tuning carbs in boats for this reason.
Aside from that, thanks for all the info on Mopars. I enjoy learning the ins and outs of what was going on back then.
