03 f250 6.0 bucking only at 60mph and up!!!
Driver's side, secound one back from the front.There was an update in the design...either will work for your truck; you can also "mis & match" them. I don't think you'll be able to find the old design since it was phased out 6-7 years ago.
Ok I finally replaced injector #4 and it was still doing it. On the test drive it stalled and the camshaft position sensor code came on so I replaced that and took it in to get reflashed. The problem is still accruing and I dunno what to check next. Icp, turbo, fuel pump? Where do I even start. Can a ficm test out fine but still not be functioning correctly. Please help
For the record, my local dealership raped me for $275 just to diagnose the three bad injectors (wanted another $1200 for parts). That's when I bought my AE; I diagnose & repair all my PSD issues since then.
The question should be what can you not do. It will allow you to buzz test, check contribution/balance read all codes on the truck (engine & chassis) along with a host of other test. Basically it will give you enough information that you should be able to find the problem without ever having your local Ford dealership look at the truck.
Some SOLID Advice here
One day I will have one of those AE too
275.00 thats the most Iv heard for a diagnostic did they change the injectors too or just Diagnostic test. I know sometimes they will throw the cost of the diagnostic towards the repair if they get to do it
And I'm sure you know where's the best place (price & customer service) to get one
That was what they charged to basically tell me I had three bad injectors on one side. After that is when they dropped the $1200 bombshell just for all four injectors on the one side (I forget the exact $$$ for labor) and I said: "no thank, I'll fix 'em myself". Don't get me wrong, I'm not anti-dealership (I used to work for a Caterpillar dealership; well aware of what goes on). I'm just against the one & only Ford dealership for 30 miles that's near me.
#29
As far as where to get one, RiffRaff has the best price you're going to find hands down....$360 with free shipping to the continental 48.
#30
one of my friends paid 1200.00 for just 2 injectors
he also sold it later for a Cumapart and now droping trannies right and left
part of his problem he does 0 reaserch and tunes them without any other mods at least thats how his ford went. right at the end the 6.0 he had was losing the tranny I told him it was the tunner but he didnt want to hear that so IDK
So lets say you did have a bad ICP sensor the proper way to verify would be hookup a mechanical gauge to the HPO to see if the ICP sensor is bad. sometimes a bad sensor is hard to spot unless it jumps wildly all over the place so a mechanical gauge verifys. AE or any gauge can only display what info its given be it right or wrong info
