7.3l injector question
I was getting around 19-20mpg in my truck I recently had 4 objectors replaced now it gets around 11mpg and smells like raw diesel at idle. It has great power now but it is terrible on mpg. Is there a way to regulate fuel going to the objectors? Or is there maybe another issue?
Did you or someone else install the injectors?
Make sure the MAP sensor hose is connected, easy to forget after installing injectors ...
Make sure hose is not clogged, especially at engine intake side. Have you tried unplugging the MAP electrical connection to verify MAP is working properly? You will need to take it for a spin and you will get a CEL light but it will go away when you plug it back in. If things run much better then sensor or hose is defective.
Any chance you have or can borrow a scanner to watch real time data, that would help isolate things quickly.
Ford mechanic installed... Forgive the ignorance but... Map sensor??? You said unplug take for a spin if it runs better replace? No I do not have a scanner or know anyone with a scanner that I could borrow... Again forgive the ignorance but by trade I am collision repair and paint not very mechanically incline.
