No I haven't done a manifold before. I have broken bolts. A little nervous about it because space is tight. Would it help if I heated them first? Or would penetrating oil be best?
I figured that was the way to get to it. But I don't have an impact wrench and I'm a girl so can't muscle the bolts. I usually depend on a long lead pipe on the end of my socket wrench for power.
Spray them with pb blaster like I said to losen rusted bolts or at least make it easier ( sea foam and pb blaster are 2 different products ), you have bolts around the manifold and 2 more where connects to the pipe.
If you weren't 700 miles away I'd say grab the parts, bring it by and we'd knock it out in an afternoon.
I had heard that hydrogen peroxide and vinegar mixed eats steel. Does anyone know if it eats aluminum? Thought maybe I could spray some on and let it eat the bolt smaller so it wouldnt bust off. But I don't want to damage the head.
