Engine Knock???
The dash gage is little more than an idiot light, it will read what you see at about 7 psi. The oil pressure needs to be verified with a mechanical gage at the oil pressure sender to get an accurate reading.
Bought a stethoscope. knocking is the same at each cylinder. Can hear it real well where the exhaust manifold connects to the exhaust piping. Doesn't sound any louder on either side. I can hear it clearer when underneath the car. Not sure if thats because All the noise from the fan and belts etc isn't there.
Gardengirls, can you post a video?, maybe we can point you in the right direction. I took apart the engine still in the vehicle (maybe I am exaggerating ) looking for bad bearings, exhaust manifolds leaks, Intake manifold leaks, new spark plugs, torque converter bolts, cracked flywheel, none of the above in my case, worn out timing chain guides was my problem and then tensioner had oil sludge on the back side preventing the piston to come out. If u can please post a video.
Here ya go.
http://www.youtube.com/user/carknock1?feature=guide
It just became due for an oil change. So I checked the oil. It was black and low. To the min line. Added some(not sure how much. I use the 5 qt jugs.) It was just changed 3000 miles ago with new filter. The video is after I put oil in.
#28
#29
Took it to a muffler shop that does free diagnosis(it seems like everyone charges now days). Confirmed the exhaust manifold was cracked. Said bolts like to break off when replacing and it would be $1000 job.
Thanks for your help n pointing me in the right direction.
I will attempt to fix myself and soak the bolts overnight and hope they don't break off.
