Hello! 1981 F100
Old 11-24-2011, 11:01 PM
MechanicJay's Avatar
MechanicJay
MechanicJay is offline
Hello! 1981 F100
Hi All,
I've been lurking here for about 6 months or so learning all I could, waiting for the day I got my truck. Well, that day has come.
I am the proud new owner of a 1981 Ford F100.
The truck has kind of a fun history. My Father In-Law bought in brand new off the lot in 1981 in Seattle. Drove it for about 15 years and 113,000 miles. Then the truck was sent it to retire on his Father In-Law's farm in south east Iowa, where they put about 12,000 miles on it over the next 10 years. The truck as been sitting for 5 years. We went to Iowa this summer to help clean out my Wife's Grandma's house and I got the old girl running, just a new battery and some ether, and she ran amazingly well on the varnish in the tank. We bounced around the farm and town in it for the week. I wasn't able to take it home to NJ then, so it's been sitting at an Uncle's house in Des Moines until last week.
Anyway the details on the truck are, as far as I can tell:
4.9L I6, 1v carb
2WD Long Box
Granny 4sp (Warner T-18)
2.75 Open rear (Axle code 01)
125,937 miles
Green on White two tone paint.
Green interior (this seems to be a bit rare)
While in Des Moines, the Uncle gave it a tune up (spark plugs, air filter, cap, rotor, wires, etc) and replaced a rotten brake line that blew on him. He also ended up putting two new tires on it, as he kept blowing spares on the tow out here (an entertaining story for another time).
Tomorrow I'll be replacing the Radiator and heater hoses as I have no idea how old they are, the rubber brake hoses and the other steel line after the split block on the rear axle, the trans and rear diff fluid...And the most important part, transferring the title and getting tags for it. I also desperately need to replace the other two tires, as one is of unknown origin, and the other is from when my FIL put tires on in '96 before sending it to Iowa!.
My plans for the truck are to use it as a semi-DD once I get it all sorted and basically to clean it up as best I can. I don't think it was ever washed the 15 years it was in Iowa, till we took the power washer to it this summer. There are some rust issues that need to be sorted, but I'm not sure quite how bad the rot is yet -- like it is worth fixing, or just get my 5 years out of it before it turns to dust.
Anyway, now for the fun part:
Pretty much as I found it on the farm.
Old 11-24-2011, 11:32 PM
Galendor's Avatar
Galendor
Galendor is offline
Originally Posted by MechanicJay
Looks like a good old girl. Refurbish her if you can. I've never seen actual moss growing out of the dash pad before this (above).
Old 11-25-2011, 07:11 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Are you sure that tranny wasn't swapped in later? That's a combo I don't see very often, usually people write in with the 300 six, one of the weaker 4 speed overdrive trannies and the very low 2.75 rearend. Should make a good daily driver with that rearend though.
Old 11-25-2011, 07:37 PM
81ChopTop's Avatar
81ChopTop
81ChopTop is offline
Congrats on the new "old" truck!! They are always worth fixing!! I'd say that green is a little more rare. I've parted out tons and tons of the '80-'86 trucks and have never seen one, usually red or brown. I do have two trucks that came with the factory teal interior though, and have never seen any more.
Good luck with the 'ol girl and keep her runnin'.
Old 11-25-2011, 07:42 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
I saw that same interior color a few weeks ago at the junkyard, usually you only see like red, blue, and tan.
Old 11-26-2011, 07:01 AM
MechanicJay
Yep, positive the trans is original. I got a bit done yesterday. Got the radiator and heater hoses replaced, got two new tires mounted and put on the front, adjusted the choke, and changed the transmission fluid.
Yipes, no wonder it was hard to shift! I didn't drive it yet, but even sitting still effort to shift is at least 1/2 with fresh clean 80/90.
Still have to do the brake lines and get to DMV -- I'm hoping to make it to DMV today. Brakes lines might be waiting a week or so, I have other things to get done around the house this weekend.
Old 11-26-2011, 09:11 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Nasty looking.....
If it were me, I would have put some ATF in there, and drove it around for a few minutes (or at least let it idle in nuetral for a while), then drained it again before refilling with 80/90.
As it is, you will likely want to repeat the drain/refill a couple times to insure all that crud is gone.
Old 11-26-2011, 03:21 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
My truck is the same exact year, engine and tranny combo, if you want to see another one, so they are around.
Old 11-26-2011, 03:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The 5th picture in post #1 shows the shift lever ****...take a look-see at it.
Assuming the shift **** is correct, it cannot be a Warner T-18 4 speed. The Warner T-18 has reverse up-towards the dash.
The New Process 435 4 speed shift pattern has reverse down-towards the seat. I don't recall what the "weak sister" 4 speed O/D's shift pattern is.
The TRANS code is marked on the Certification Label:
1980/83: A = New Process 435 / F = Warner T-18 / T = RAT/RUG 4 Speed Overdrive.
Originally Posted by 81-F-150-Explorer
My truck is the same exact year, engine and tranny combo.
But...you have an F150, the OP's truck is an F100. Does your Warner T-18 have a reverse shift pattern that is down...towards the seat? I think not.
Old 11-26-2011, 04:06 PM
MechanicJay
Trans code is F on the label. It's dark out so I can't get a good pic. I remember reading on these forums somewhere that the older T-18s had reverse up, and the later ones were down.
Also when I was under the truck I saw a giant Borg-Warner stamped on the trans case.
Old 11-26-2011, 04:38 PM
Junior Junior's Avatar
Junior Junior
Junior Junior is offline
Slick truck! Love the two-tone. Now do yourself a favor and re-route that fuel filter anywhere but right on the exhaust griddle!
Old 11-26-2011, 04:44 PM
bruno2's Avatar
bruno2
bruno2 is offline
This leads me to belive the tranny is a Borg Warner.
Old 11-26-2011, 06:17 PM
Rogue_Wulff
Without a doubt. I had a dickens of a time with vapor locking the first summer I had my 300 powered truck. It was all caused by fuel boiling inside the fuel filter, sitting in that exact same location. Relocated the filter, and haven't had a repeat occurance in over 13 years now.......
Old 11-26-2011, 06:30 PM
81-F-150-Explorer
He has a T-18, I can tell from the picture where he's draining the "green water logged goop" out of it.
The T-18 shift pattern changed to, reverse to the right then down toward the seat in 1976. The NP-435 and the T-18 has the same shift pattern in 1981. One way to tell them apart is the NP-435 is "sync-ed" in all foward gears where the T-18 is only "sync-ed" in second third and fourth.
My 1973 with the T-18 was how you describe, reverse was to the right and UP.
So yes my T-18 in my 1981, the reverse gear does go to the right then down.
The Clark (Tremec) 3-speed overdrive is a standard H pattern, except the reverse gear, you have to "push" down on the lever, then move it left then up toward the dash.
Old 11-26-2011, 06:42 PM
81-F-150-Explorer
That is actually the factory location for the FG-44-B motorcraft fuel filter.
I would get the correct metal filter and swap out the aftermarket plastic one if keeping it in the same place.
I did notice that by 1984 they did move it to a threaded type that threads right into the carb fuel bowl.
Quick Reply: Hello! 1981 F100
