Roll Pan for '49
Old 11-24-2011, 10:37 PM
divermo's Avatar
divermo
divermo is offline
Texan
Roll Pan for '49
Looking for a rear roll Pan for my '49. anyone know who makes or sells any.
Old 11-25-2011, 07:24 AM
tlb's Avatar
tlb
tlb is offline
Give Hot Rods Trucks a call. That is were i got mine. You can get them with or without a recess for the license plate.
Old 11-25-2011, 08:22 AM
mtflat's Avatar
mtflat
mtflat is offline
If your truck is stock, Mack Products, Moberly MO has what you want.
Old 11-25-2011, 10:17 AM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
I beleive mine came from Dennis Carpenter
Old 11-25-2011, 11:27 AM
Jimmy49Ford's Avatar
Jimmy49Ford
Jimmy49Ford is offline
Thumbs up
Thats a pretty picture. What size tires do you have wedged in out back? I have some 295/50/15's that about similar to those. Pretty tough looking.
Jim
Old 11-25-2011, 05:38 PM
underthebridgejim
FTE fan
Jim
Good eye ,you got it 295/50/15s
Old 11-25-2011, 07:11 PM
divermo's Avatar
divermo
divermo is offline
Texan
Thanks Everyone, Ya'll are the Best
Old 11-25-2011, 09:21 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Thanks for the info on the roll pan. By the way, are you still running the stock rear axle? I'm liking the way those tires sit in your fenders and they look really good with the roll pan.
Old 11-25-2011, 10:39 PM
underthebridgejim
FTE fan
No its not the original rearend i dont think. 2 pos back put in this 10 bolt, so i had the wheels made with 5 1/2 "" back space, wich is what you see. There is still a few inches of clearence. Id like to bring the wheels in a littel more, maybe bigger wheels, maybe just less backspace, maybe shorter houseing with tubs, I dont know. I guess the first step will be to to inspect the rearend and see what it is, and what shape its in.
Old 11-26-2011, 09:40 PM
Jimmy49Ford
Thumbs up
Hey Jim,
If you don't mind me bugging you again, what size wheels are you using with those 295's? I currently have 8" (wide) wheels with a 4" back spacing. The problem is, they are an older aluminum style and no matter what I try, I have one that leaks air pretty bad at the bead. I've re-mounted it, bead sealer, etc. with no luck. Do you run a 10" wide wheel? Mid-Fifty offers an version of the stock steelies that are 15 x 10" with a 5" back spacing, but real estate tucked in that rear fender is already getting scarce. Let me know if you have any opinion/knowledge on this and what you're running. If you wouldn't mind, I'd love to see some more pictures of these tires/wheels on your truck!
Thanks!
Jim
Old 11-26-2011, 11:18 PM
underthebridgejim
FTE fan
Hey Jim,
Thanks!
Jim
Yes my rims are 10" wide with 5 1/2' backspaceing, I believe i had them made up at Stockton wheel. I checked the BF Goodrich chart and it recomends 8' to 10' rims on 295/15s, 9.5" rims will give a tire width of 12.2". Im sorry but I dont know the width of my rear axels. PS I just found an old note in a box of reciepts , and it has the backspaceing as 4 1/2", Im not sure but I think there 5 1/2" Backspaceing. If you need to know anything super accurate send me a PM and Ill go measure whatever you need no problem, its just dark and cold at the moment.
Connecticut Calvin
WTB - Parts & other
05-11-2015 05:49 AM
93Flarey
02-22-2011 05:22 PM
bememe
09-10-2007 12:33 AM
beedevil1973
07-02-2006 07:26 PM
FX4Range R
Paint & Bodywork
10-21-2003 10:13 PM
Quick Reply: Roll Pan for '49
