Stainless Steel Window Visors for CC
I've sent an email to their customer support referencing the "no drill" in their description. I'll update when I get a response.
Be sure and let us know what they do about this. I am going to have a set of those soon one way or another and I am curious what they suggest.
Well, I though I had better update things here. After getting my "little" Jeep project done on Saturday morning and freeing up the shop, I got the Ventshades that I got for Christmas installed in the afternoon. The fit was less than perfect, but I really like them It is exactly the look I was going for. Each ventshade is secured by four screws so I know they're not going anywhere. The instructions state that you should start with the screw in the front and work your way back, using a center punch and 5/64" drill bit to make pilot holes for the screws. After I did the first couple with the center punch I just skipped that step since my bit was good and sharp. The center punch tends to chip the paint off in a larger diameter than the hole so using the drill bit alone avoids this and makes a nice clean hole. I started with my front doors first and ended up with an extra hole in the driver side door because I didn't have it lined up the way I wanted it when I drilled the first hole. I did the fronts first on purpose since I plan to replace them as part of my bodywork plans for the truck. Just take your time on the first one and be careful (you are, after all drilling holes in your truck) and they'll turn out just fine.
The contour of the rear portion of the shades for the rear doors isn't
perfect, but unless you're after the show truck look, I think they look just fine. Oh and pay no attention to that big dent in the roof. The PO did that somehow. Makes a nice place to lay the screwdriver without it rolling off the roof .
Sorry for the marginal picture quality. The lighting in my shop isn't that great and it was getting dark outside. I'm looking forward to being able to leave the windows down a little this summer without having to worry about the rain.
Nate, your truck looks way too cool now with those visors on but what about us poor guys with just a Super Cap (ie-- don't have back doors)?? Do they have a short piece for the back side windows too (so it matches the front) or do I just get a front door only?? After seeing some of these F-350 CC's on FTE, I sometimes wish I had held out for one of them instead!
#28
#29
