New to forum: Dentside Cummins Swap
Hi Gang, I have spent many hours looking in on this forum, and found lots of useful info. I am getting ready to embark on a project. I am about to buy a 1979 F250 Super Cab 4x4 with 3speed auto, appears to be a short bed from the pics. I will ask the current owner tomorrow what bed configuration it has. I am planning on swapping in a Cummins, I have a very talented friend who is a fabricator who will be assisting me. I have a line on a 2001 donor dodge w/ 24V, NV 5600 2WD that was rolled.
My first question is: does the F250 Super Cab 4X4 have a divorced transfer case, and if so, how difficult will it be to adapt the NV5600 to the transfer case?
My second question is: is it going to be a nightmare swapping in all the electronics and fuel management from the donor into the dentside?
I have searched the forum for a similar build with no luck...
Thanks for the guidance and sorry for any newbie misteps,
Matt
San Andreas, CA
Matt
San Andreas, CA
Hi & welcome. I BELIEVE the '79 Supercab should have a married 205 t-case.
As far as doing a divorced 205 behind the nv5600 - get a 2wd 5600. I have a 2wd NV4500 going in my '74 crew with a divorced 205 & it looks like I may have to shorten the middle driveshaft just a bit.
As for forums - check the motor swap forum on here. There's also a BUNCH of good cummins swaps into dentsides in the shop/fabrication/swap forum over at Dodge Cummins Diesel Forum
They will know what to do about the electrical - and also probably ho to go about putting the married 205 behind the 5600 if you want to.
firemedicober
02-08-2012 01:03 PM
lref250ld
04-03-2011 05:21 PM
