Exhaust Fluid System Fault Message
on
Same thing here. It was in the sixties on Sunday when this occurred. I don't want to turn this into a hpfp issue by any means but this could be a real inconvenience when you are nowhere near a dealership. This limiting the truck to 50 mph over emissions equipment is b.s.
I got so frustrated with mine last winter I ended up deleting it. Like you I have no time to go to the dealer every other week to clear codes (but never fix anything). I hope this is an isolated incident for you but clearing codes (and even replacing parts) never got mine fixed. Likely would have fixed it evenually. I gave them 4 month and about 20 days with the truck at dealer and never got it fixed. Thats when I pulled the pin. Good luck.
Thanks
Thanks
Thanks
on
I had P164A / P2A00 (NOX sensor) CEL issues as well though at the same time.
Thanks
Well, I'm in the boat with y'all now. 42 Miles till limited at this point and the Dealer can't get me in for another day and a half... My DEF tank is full and display says level ok. Just keeps showing me a system failure...
This, a new tire (that only had 7900 miles on it) and a sick dog is really dragging this week straight to hell.
Sorry, just needed to vent. At least it didn't happen when I was towing to TX and back to CO last weekend.
So the truck recognizes that the DEF tank is full, yet it says you only have 42 miles until the 55 MPH speed limit? I'm no mechanic, but perhaps you should disconnect your batteries for awhile to reset things. Sounds like your PCM isn't correlating the full tank condition to the NOT limiting speed.
Just a suggestion, hope your week goes better!
I put in a 2 1/2 gallon jug of DEF and started the truck a couple of times and got an "800 miles remaining" warning each restart for the rest of the afternoon.
The next morning, when I started the truck, I got no warnings and haven't had any for a couple days now.
So I'm not real sure what the reset strategy is for the DEF at this point. It didn't reset after filling half way, but it reset after sitting overnight.
Soooo, in order to avoid the dreaded P164A code, I would think that there would/could be some sort of "DEF Full" emulator plug with the correct impeadence, one could simply swap out with the sending unit on the tank.
Im all about hugging a tree, but when your dumping more evil chemicals chasing a fault than your saving sort of seem dumb.
Leo
Leo
on
I'm not sure what's so dreaded about the P164A NOx sensor code since I found that it didn't really change how the vehicle drove at all...
As far as I understand, the DEF tank uses a 3 step sensor, I guess it's a liquid conductivity sensor like the 'water in fuel' sensor would be. There's a common probe that goes all the way to the bottom and then 3 other ones for low/half/full. That's why when you fill it you can't fill it partially, you have to fill it enough to cover the sensor looking at the next step up for it to register a filled DEF tank.
Thats how I understand it as well. I would think that the computer doesnt track any flow rate values. So to plug in an imulator that would show 1/2 full...Or 1/2 empty(lol) at all times would be no big deal. Then, every time you checked oil or fuel, or what ever, you could just top it off. And, if you stuck out in now where land, you would not get stranded.
Leo
Leo
#28
Just bought my truck 3 weeks ago. It has 1400 miles on it and we just loaded it up for our annual family vacation to Utah for some skiing and boarding.
On my way home from work tonight "Exhaust Fluid System Fault" pops up. You gotta be kidding me... 3 weeks old, 1400 miles and the night before we leave for vacation I have to go first thing to the dealer tomorrow morning to get this fixed... very frustrating.
Also if anyone can help I thought you could initiate an Active Regen and possibly even delay the Regen on the 2012's? Am I mistaken? I thought for sure you could at least delay the regen but I can not find it anywhere in the center info screen.
#29
