starting a Five Tire Rotation
Ive thought about that a few times, but never got around to doing it. I always did however keep a same size spare just in case I got a flat on my 4x4s. A friend messed up his rig by running an offsize spare before so I made sure I did not have that problem.
Did you already order the 265s?
I did not order the 265s yet. (I may just buy 4 for now and buy the 5th in 5000 miles for the first rotation, just use best old tire as spare until then, I haven't decided yet.)
The situation I had when I got my 2004 Ex last year was a new 0 mile spare tire and (gray steel) wheel that had never been used... but was 6 years old. Some sources say a tire shouldn't be used after it is 6 years old, some say 10 years old... not a risk worth taking with wife + 3 kids in the Ex most of the time.
You might want to look into some 285's perhaps since you need to get new ones, it was a big difference to me from the 265's.
Now that I think back on it, I honestly can not remember a time where I would have needed a 5th tire in a normal rotation yet. I would always either just keep the best old tire as a spare or have the tire shop throw a decent "fresher" spare into the deal.
I definately agree with you on not using old tires, the safety of the family and everyone else on the road is not worth it.
I tried the 5 tire rotation...and realized it was more trouble than I cared for...and it's more expensive since you are buying 5 tires. You don't really gain any advantage from this IMO.
tires rot. Especially in hot dry climates. The rubber dry-rots on the sidewalls. My Expy had the ones we were driving on rot out in 3yrs and 22k miles. I just replaced them due to crappy wear and cracks in the treads.
I personally wouldn't run an old tire. My truck still has the factory tire/spare and that thing is rotted. I'm scared to even put it on the truck if I were to have a flat. The sidewall is a mass of tracks. Never been on the ground, still has all the rubber nubbies on the tread.
As far as putting new "spare" rubber on, I also used to take the best tire from the 4 being replaced and replacing the old spare. Helps keep the spare tire from being a rotted out waste.
I looked at/thought about the 285's, but I rarely go off road and the taller tire would make it harder on the motor/trans to pull my (long and heavy) travel trailer.
We camped 5 or 6 times at the campsite where we store our travel trailer. I used hurricane irene as an excuse for a 300 mile round trip West to avoid the storm.
I always though you couldn't move a steel-belted tire from the driver's
to pass side (and vice-versa) because the change in rotation direction
would cause the belts to separate?
Thus, I've always just done front to back tire rotation for all my vehicles,
over the last 30 years....
I also always save the best old tire as a spare, but my Ex has a
"new" Mich LTX M/S so I will likely keep it when I buy 4 new tires
early next year. Although, I am re-thinking going with 285s
which would force a 5 tire purchase (if the dealer doesn't have an old one).
Most owner's manuals specify to cross the tires to the drive wheels when rotating. IE LF goes to RR, RR goes to RF, RF goes to LR, LR goes to LF. (RWD vehicle) Except for a few specialized tires that are designed to only rotate one direction (high perf) , most all tires are made to be roated like that.
I vaguely recall there being some limitations with older tire designs, but it's been a while. Long enough that any tire affected will be long past it's life.
Personally, I would use an old spare as long as it passed a visual check. To me, I would plan to use a spare for a short limited time anyway. (Unless it was with a 5 tire rotation) Probably safer than the mini spare that most cars use.
