Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- Why Does My Brake Pedal Go to the Floor?
Guide to diagnose trouble and recommended solutions
Help - E350 brake pedal goes to floor - only when running!
Truck is 1992 E350 cube dual wheel cab and chassis 5.8L
Initial problem - Front brake lines rusted out, lost pressure, MC bled dry.
After replacing all front brake lines and bleeding front and rears, I got good solid
pedal with engine off, I mean I can push long and hard and it stays firm.
When I start engine, the pedal slowly goes to the floor with almost no resistance
and you hear a woosh from the booster until it gets to a few inches from the floor
and the pedal firms up and the brakes operate (stopping power).
Repeated pumping has NO effect on firmness nor does the pedal pump up or rise.
So I replaced the master cylinder with a NAPA part and bench bled it for a good 20 strokes until only fluid was recirculating.
Installed MC and then bled brakes again (full quart) until no air came from bleeders.
I still have the same problem.
The pedal is high and firm and stays firm when I stand on it with the engine off.
Start the engine and the pedal sinks nearly to the floor before it works.
I'll try bleeding the rabs but I don't get how it could have that much air in the system if
the pedal is high and firm and the brakes work fine with no boost. I confess I don't know
how the rabs system actually operates so I'll take your word.
Is it possible the atmospheric valve in the booster is not working therefore I'm getting an
over boost situation and that is causing the pedal to travel so far?
The booster has 220k miles on it and is only $100 so I don't mind trying it.
I drove it with and without vacuum boost.
With boost the pedal slowly sinks to 2" from the floor hissing the whole way then the
brakes work and the pedal doesn't go all the way to the floor. If I pump the brakes it
does not build pedal like it would if it had air in the system. It just keeps making the
hissing sound and returns to about 2" from the floor then works.
With vacuum removed the pedal is high and firm and the brakes operate normally but
with no power assist so of course you have to push really hard.
Still trying to fix my low pedal problem....
I read here that a bad RABS valve can cause low pedal.
It also says the ABS light doesn't always go on if the dump valve is leaking.
Kelsey-Hayes RWAL Antilock Brakes
On my 97(7.3PS) the RABS is bled via a Ford capable diagnostic computer. And you can bet there is air in the RABS if the master cylinder went dry.
Do you have a cover held on by a bail over your master cylinder, Covering both front brake and rear brake reservoirs?
If so, the front brakes are the larger of the two reservoirs.
Fords412,
On the RABS dump valve on driver's frame rail, there is a lerge bolt (1 1/4?), remove this bolt ( careful it is under tension from the spring). Remove the spring and replace the bolt ( you will not lose fluid). Bleed the system and you should have a good pedal. If you do, you have the option of leaving the spring out (it will revert to "regular" brakes, or replace the dump valve to restore ABS. The ABS light will not illuminate if you leave the spring out. Good luck,
Ed
ASE Certified Master Technician
ee35805@yahoo.com
Ed
ee35805@yahoo.com
