I can't remember if that plug has an oring you just can't replace while in the truck, or if the pump has to be worked on. Send joey@terminatorengineering and email and check with him on options and good prices if you need it worked on.
If you can't visually see where the oil is coming from I can't think of anything else it would be. See if someone else clarifies the plug we're talking about.
No o-ring just locktite. And yes if you dont see, maybe thats the problem
Originally Posted by Mdt1992
they have a kit to replace that plug with one with longer threads and new o-ring beleive the hpop has to be pulled though
I have not e-mailed him yet, but sending mine in to him for the T500 would be about 1/4 the price of a replacement from NAPA as long as it will work with the stock injectors and tune, and I will have a leg up once I can afford to start modding it.
