Please Help 2000 f-650 with 7.3 oil pan replacement
Hey Guys.. any help here will really apreciated. I pulled out a damged oil pan on my 2000 f650 with 7.3 PS. I just cant quite get the new one in. I removed the two front bolts and mounts under radiator and jacked motor a couple inches. I am close but not in... I keep hitting the front cross member. I did remove the tube fill from the oil pump. removed starter. Any ideas... I just dont want to pull the motor out. Was not sure if I kept jacking the motor I would Screw something up.....again it is very close.
I Know in the smaller trucks you have to pull the motor I really thought this could get in without doing that in the f650
Any help thank you in advance
prgav
10-26-2011 07:51 AM
fierogt
34
04-29-2008 02:52 PM
