Oil in Coolant...
with all the info on here its not to bad a job
heres some stuff to study
https://www.ford-trucks.com/ford-man...%20Removal.pdf
and here
https://www.ford-trucks.com/ford-man...%20removal.pdf
thats the main parts
and here
get it apart open all drains hoses ect...and stuff a Garden hose in the coolant system with hot water if you can reverse flush everything heater core radiator core engine blockect......
at least with the oil system there wont be much oil left taking the oil cooler out Tim has a great Idea to undo the oil rails off the injectors
I just my picked up my new oil cooler. I guess I got lucky the local dealer could get one shipped in. Tousley and most everyone else is on back order. They said there were 63 orders ahead of mine! Not sure how they found it but thank God they did. Without going overboard, are there anything others parts I should replace while I am in this far?
If it hasn't been done already. I would go in and replace your STC fitting on the HPOP. Not much more work and you'll be very close to it when you pull out the oil cooler. The intake gaskets can be re-used if they are in good shape iirc.
Intake gaskets can be reused if they dont get jacked coming out
I changed my intake gaskets out cuz thats just me but I did nick one coming out its kinda a PIA with the wire harness there my first time
plus it comes with the little egr hose you said was leaking
but get a new turbo hardware kit and put antiseize on the bolts and the V-band clamps when going back together
you also will probably want to get a new IPR since it has a screen that gets clogged up and your mixed coolant in with the oil and may have trashed it
Are you going with an EGR Deleate or a BPD egr cooler
If you have a square egr cooler it must be replaced or deleated
If you have a round egr cooler it should be pressurre checked or replaced or deleated
my egr deleate came with a new hose as well that little one
here are some pics when I did my oil cooler egr stuff
Ford Truck Enthusiasts Forums - BLADE35's Albums
check it out^^^^^^^^^^^^^^^^
