exhaust crossover passage in intake
A gas engine has many different systems, the heat crossover is only a part of a quick heating system. When cold start's occure the exhaust crossover valve should close wich makes hot exhaust, crossover underneath the intake manifold wich heats up the center of the engine as well as the fuel and air. There is usually a hot air flap on the air cleaner that will close off and allow the hot air to enter the air cleaner. Both of these are trying to heat the engine quickly for better drivability. For racing and street use, people usually block these passages and remove the exhaust valve.
jack orchard
17
12-27-2015 12:59 PM
Bullitt233
12-11-2015 09:05 AM
husker77
04-23-2012 02:15 PM
LARIAT 85
08-01-2011 03:35 PM
