86 Ford Ranger won't start
Old 10-22-2011, 08:20 PM
hwyman1998's Avatar
hwyman1998
hwyman1998 is offline
My ranger wont start, has fuel and spark. does appear to be iot of time, pulled dist cap rotor in right spot for tdc # 1 cylinder.
Old 10-22-2011, 08:33 PM
Dutter's Avatar
Dutter
Dutter is offline
Ill need some more info, what size motor is it and is it turning over
Old 10-22-2011, 09:34 PM
hwyman1998's Avatar
hwyman1998
2.9 liter v6 and yes it turns over fine
Old 10-22-2011, 11:29 PM
Dutter's Avatar
Dutter
Dutter is offline
Was it running when u got it,, are u sure the timing is right, like the distributor cap and timing chain
Old 10-23-2011, 09:23 AM
Furyus1's Avatar
Furyus1
Furyus1 is offline
When you say it has fuel, does the fuel pump run when you first turn the key on?
Old 10-23-2011, 10:46 AM
Dutter's Avatar
Dutter
Dutter is offline
Yeah type up a good paragraph about how it started to die, and what u do and hear it doing when u go to start
Old 10-23-2011, 02:32 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Check for fuel pressure at rail by depressing the schrader valve at FPR........No spray, no fuel press., no run.
Old 10-23-2011, 03:37 PM
hwyman1998's Avatar
hwyman1998
Yes it was running, I drove it around the block and it sputtered and died. Fuel guage read empty so I thought it was out of fuel. It started once and ran very rough. Tank now at 1/4 full so I replaced filters ( in-line and canister) because I thought they were plugged. I unplugged the inertia switch to relieve the fuel pressure in lines and it tried to start. After replacing filters still won't start. It has plenty of fuel pressure. rotated engine to tdc and rotor appears to be in correct place.
Old 10-23-2011, 07:14 PM
Dutter's Avatar
Dutter
Dutter is offline
The inertia switch has to be hooked up for the fuel pump to turn on, Or you can cut the 2 wires and twist them together to complete the secret. And also check ALL of your fuse, Do that and get back to use, I was haven the same problem with my truck and i found out the inertia switch wire was grounding out
Old 10-25-2011, 09:54 PM
hwyman1998's Avatar
hwyman1998
I jumped inertia switch no luck. I replaced coil that didn't work. It smells flooded, any ideas?
Old 10-25-2011, 10:20 PM
Dutter's Avatar
Dutter
Dutter is offline
Did u check ALL fuses, because if the inertia switch went bad it would have blown a little fuse in the fuse box under the hood, welll thats were it was on my ranger, but check alll of the fuses
Old 10-26-2011, 11:46 AM
flyinmonkeys32's Avatar
flyinmonkeys32
flyinmonkeys32 is offline
I have an 87 2.9L and am having the exact same problem right now, I have no fuel pressure. Where is your fuse box under the hood? I cant find one anywhere. The truck ran fine yesterday other than my battery issues. I went to start it this morning and had no fuel pump sound and now no pressure. And what does the inertia switch look like?
Old 10-26-2011, 05:06 PM
Dutter's Avatar
Dutter
Dutter is offline
You should see a black box of some sort, and the switch has a green and red wires goin to in and mine was gray with a red button and was under the glove box, check ur owners manual and it should say were it was, But if that did trip or fail it will blow a fuse so also look up were they are in the book
Old 10-27-2011, 06:58 PM
87_2.9_4x4_ranger's Avatar
87_2.9_4x4_ranger
87_2.9_4x4_ranger is offline
There is no fuse box under the hood there is only Fusible links. the only fuse box is in the dash under the steering wheel. On the 87 2.9's
Old 10-27-2011, 07:20 PM
flyinmonkeys32
I figured out my problem... kind of ashamed to admit it lol, but it was just simply the crappy ground connector for the fuel pump right off the battery that got disconnected and then hid under everything else. Still don't know about my battery issues tho.
Quick Reply: 86 Ford Ranger won't start
