JET Performance 70704 - JET Shift Commands
I ran a search before posting and got one thread where it was only mentioned.
Anyone use this? How it its performance? Right choice for firming up my plow truck's shifts?
Any input or options are welcome. I dont want to hear punisher valve body.... I have no reason for that on this truck.
on
you can make the same thing yourself via a series of resistors hooked to a multi switch,or just a potentiometer probably.
if all you want is one setting,then don't even mess with everything.just place one resistor between the lines.
search for resistor mod for e40d.it's very easy.you can try diff resistors until you get what your after too.
nothing beats actually modifying the valve body though.you don't need to buy one,you can mod it yourself with a shift kit in just an afternoon getting messy.
just, don't loose your *****;
https://www.ford-trucks.com/forums/8...ighlight=*****
F-250 restorer
03-18-2017 05:52 PM
lawdawg79
12-07-2015 04:12 PM
