My junk-O-rific 59'
#61
Thanks for the pics Blacked out!!! I just got an 05 CV PI front end this week to go into my '57 Panel. By what I've read, the swap isn't too hard. Yours looks good!! I'm already running a 351W with an FMX, but I'll swap the trans for an AOD while I have it out. I think I'll also swap an early CV rear into it to make the rear wheels look better. Keep up the post. It's looking Good!!
Barring that a late 99-early 2000 Crown Vic cop car (P71 in VIN) should have an 8.8 with 3.55 gears,check for traction lok in the axle code on the door sticker.
Any of those will give factory rear disc brakes,and you can grab the master cylinder at the same time.
#62
I am still sorting out the PS line, but once the rest of my parts get here I will explain the tragedy of my last 2 weeks. No here is the dash panel inspired by the pictures Walston so kindly posted. Mine is not as beautiful and now I wished I had welded from the back side. I thought a nice bead around the edge would look cool, but the old and new metal didn't jive and truthishly I suck at welding thin stuff. I see bondo in my future.
Cut out the center
welded and drilled
Cut out the center
welded and drilled
#64
glad I could be of some help. last night me and the flapper disc spent some quality time together and I got the edges roughed out. I also ended up fabbing a bracket to brace up the steering column by use of the brake booster bracket. It is only bolted to the dash, now its super strong!!!
dash
closer
dash
closer
#66
#68
#69
Good news!! The bondo turned out to be fine, I am just slow. $ coats of bondo WITH HARDNER and bam looking good. I forgot to take pics until I got the first coat of primer (not sanded yet)
NOw onto the PS lines.....what a cluster. So far I have give or take $150 in both lines. Going from the CV rack to a saginaw pump has been a real pain. The CV rack takes a proprietary fitting which the salvage yard didn't leave me with $45 for the pressure and $26 for the return. The return was just fine. The Pressure hose was a complete peice of garbage/
(space held for pic)
I only ended up using 3inces of that line and had NAPA make me a line with a JCI fitting on one end and a compression fitting on the other.
I had to buy an AN (same as JCI) coupler and an adapter to go from the saginaw pump (later model) 16mmx1.5mm Oring to AN to the line. Mistakes were made by myself and NAPA, I sure hope it doesn't leak..... finished line
And installed.
BTW does anyone know what 3 wires split off the middle of the bundle and head toward the engine?
And installed.
#73
Still chipping away. Wiring is 90% complete. I had a rough go around with the dash panel. I should have consulted with my father in law (airplane painter) earlier and I would have side stepped my folly. Lesson learned. After stripping all paint and primer, here we are with 2 coats o it.
I have all my gauges that I will use for now, I also adapted the old speeometer cable with the correct gear for the AOD trans and that is installed. I realized my air cleaner hits the wiper motor, so a smaller one is on order. Down to the last few items...made a bracket for the proportioning valve. Then its offf to plumb the lines and finish painting the dash, wires and BAM fire in the hole!
