D8VE BLOCK INFO
D8VE BLOCK INFO
If any of you run across a D8VE 302 block, be advised now, do not pass on these little known gems. The ones with the A3A suffix have the big Hi-po/Mexican main caps and are for all intents and purposes, 289 Hi-Po/Mexican blocks. Those with a 3A suffix are the same blocks, but have the std main caps. In addition to this info, I have found in weighing several early blocks that the Mexican block is the same as the early blocks in weight. They are no thicker than the other early (pre 1980) blocks.
As of this moment,(all are for sale) I've got a D1ZM Mex block, a D8VE-A3A block, a D8VE 3A block and a C8OE block in my possesion. All four are stipped down, cleaned and have the main caps bolted down. I weighed all four blocks. The Mex block weighs 136 lbs (std bore), The D8VE-A3A weighs 134 lbs (it's 60 over bore), the C8OE weighs 135 lbs (std bore) as does the D8VE-3A (20 overbore). I'm unable to post pics here, but can email them to anyone interested.
You've misread the letters here, your "S" should be a "3". The 8O6 is the date code, that's eight "D (not zero) six, meaning it was cast on the sixth day of April ("D") 1978. Congrats, you've got the big main capped block, for all intents and purposes the same as the 289 Hi-Po/Mexican block.
newbie alert lol sorry guys I'm new to this stuff. I have been searching for a good 302 block to build up and put in my 85 f150 that I've already swapped efi to carb. I ran across one of these D8VE-6015 blocks the guy had it boiled and bored 60 over and has brass freeze plugs in and it comes with a crank he said has been shaved.... like I said I'm a newbie, would this work with my aod transmission after I built it up and is $250 a fair price for it? I understand my 85 302 is a roller engine, what's the difference if any? If this is an ideal block for my project would gt 40 heads work with it? Thanks in advance for any answers and advice you can provide
And more then likely the engine is still in good shape if that SUV is in the junk yard due to crash damage. Which means that you may be able to just put in fresh rings and bearings after a light hone of the cylinders. You can reuse the pistons, etc. if they check out OK and this will save you cash!
