PM-22-A Motorcraft Cetane Booster/Additive
It is out of stock but they have a great price.
[PM-22-GAL] Motorcraft Diesel Cetane Booster and Performance Improver_GALLON(PM22A) - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
I tried a 20 ounce bottle from my dealer ($9 with tax) and have already bested my best mpg per tank by .5 mpg. I have over 34k miles. I wanted to buy a gallon of PM-22-Gal, but had to settle for 8 twenty ounce bottles. With shipping I paid $71.27 from your link. That should last me over 16,000 miles, 4 months and add 7 cents per gallon of fuel. I may try every other tank treatments.
But using a non-recommended brand and faced with a HPFP warranty repair, will a non-recommended brand be considered better, OK or worse than not using a Cetane booster? Only Ford warranty bean counters can tell you that.
I'd rather not take a chance myself.
It seems the reason for all of the talk specifically using the Motorcraft brand is because of Rick's recent warranty/non-warranty fiasco. If Ford recommends using their brand Cetane booster and one has a HPFP problem, a stack of receipts for their recommended product will hopefully better your cause for a proper HPFP warranty repair.
What I find as a kick-in-the-nutz concerning everyone running scared making sure adequate steps are being taken to cover themselves...
We offer you this unbelievable truck with a new in-house engineered diesel engine that contains state-of-the-art technology for an unbelievable price.
But wait...for an extra $10/month, we also will allow you to possibly maintain your warranty on your new vehicle with our high margin Cetane booster that has been tested to be just good enough to counter the horrible fuel quality available to you, the consumer.
Of course, in jest...or is it?
Couple of thoughts here.
First of all, contaminated fuel is contaminated fuel. There is NOTHING you will put in your tank that will assuredly help with this problem. If Ford denies a warranty claim for this, it will most likely be because of contaminated fuel, not low lubricity. I have never heard of them testing for proper lubricity, and I find it likely that some of these denied claims were because of superficial corrosion which led to the denied claim where the root cause was insufficient lubricity.
Ford will not give a crap if you use their additive when they deny a claim for contaminated fuel. Contaminated means contaminated, not untreated.
So an additive will not protect you from a warranty standpoint unless they deny it for low lubricity, which I've never seen. I do believe that it will significantly reduce the risk of failure though, and if you happen to have some superficial corrosion on your pump it would save you thou$ands by keeping your pump and system alive. That's why I used it.
Use the Motorcraft because you believe it's the best. NOT because it will help you in the event of a warranty denial.
I get the stuff at my dealer in the gallon container. Since it's hard to pour from the gallon container I've switched it over to used vodka bottles for easy pouring.
Also note that I've heard that using the water bottles is a bad idea because they contain some sort of coating that may come off and pollute the additive so I will be drinking more frappuccino
I keep a spare bottle in the seat pocket behind my seat and have not had any issues with leakage.
I just keep my old bottles and fill one to the 4 oz. line and another to about 2 oz., covers me if I am filling the tank or its about half tank.
I think someone already asked this, is there anywhere that compares the different brands? What makes some think Power Service is so much better than Motorcraft? I will use whatever is best, but I would like something better than just an advertisement telling me that.
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
#28
This is an older study from 2007 but it still has some good information.
Has anyone been using Opti-Lube or Schaeffer? They seem to be some of the best in the study.
#30
