Help! Ignition switch pigtail
LMC carries a pigtail, but I don't know if it covers '73 or not. There online catalog will say.
EDIT: Yep, it says 73-76. You should be good. Also, if Rock Auto has it, it would probably be cheaper. You'll just want to make sure that the replacement pigtail has the same gauge wires as the original; this is not always the case with replacement connectors (and heavy current goes through this switch).
LMC link (see #24): http://www.lmctruck.com/icatalog/fc/full.aspx?Page=140
How many more suggestions do you need?
1) I gave you the exact line item out of LMC
2) pidaster got one at the store, which means you go to the desk and they look it up and bring it to you, or order it for you
3) I also suggested you look it up on Rock Auto's website; they'll have it from the same manufacturer that LMC gets it from
You take it from here.
Guntherexpress
03-28-2017 03:39 PM
Daddywags
10-19-2011 10:38 PM
